Author Topic: What could have done this!? Hole in Petcock bowl (pic)  (Read 2413 times)
Offline ericmu17
« on: August 20, 2012, 09:47:04 AM »
I just discovered a hole in the bottom of my petcock bowl.... is this common?
I have new one on the way but I want to prevent this from happening to my new one.
Offline Teatimetim
Re: What could have done this!? Hole in Petcock bowl (pic)
« Reply #1 on: August 20, 2012, 09:58:38 AM »
prevention would I think be cleaning of the float bowl often..  water I would guess on that.  but also debre building up.
Bikes I own:
1974 CB550K
1971 CB450
Offline CBNJ74
  • Sweep the leg!
« Reply #2 on: August 20, 2012, 10:01:14 AM »
Holy cow! a teeny tiny sniper camped out under your bike?
What did the screen look like? tank flush maybe?
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #3 on: August 20, 2012, 10:02:21 AM »
Wow.  If that wasn't punctured by some physical force, it must have been corrosion..So, yeah cleaning the bowl every once in a while, and making sure the screen is intact inside the petcock should prevent that from happening in the future.  Of course, we are dealing with 30+ year old Japanese pot metal here, so there's no guarantees I guess.
Offline srbakker
  • Spam & Eggs
« Reply #4 on: August 20, 2012, 10:05:25 AM »
If you don't mind shelling out $35, this is one way to prevent corrosion:
http://www.jokermachine.com/itemcafe2004.asp?ItemID=660&CategoryID=85&Placeholder=
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline kerryb
  • Not a very
« Reply #5 on: August 20, 2012, 10:09:46 AM »
it appears you have been harboring a 'bowl weevil",  you'll want to clean the carbs soon cause that's where they like to build a nest!
Offline srbakker
  • Spam & Eggs
« Reply #6 on: August 20, 2012, 12:41:04 PM »
 :P
1975 CB750 K5
2007 Triumph Tiger
Offline aperry
« Reply #7 on: August 20, 2012, 02:17:18 PM »
I don't know what bike you have, but I got a hole in my petcock bowl as well.  Mine was not directly on the bottom, rather it was around the curved part (toward the bottom).  However, both areas look pretty thin.
My petcock makes contact with part of the carbs when I install it.  I need to softly push the tank out to the right side a little bit when installing it.  Otherwise it interferes with the carbs.  I'm pretty sure my hole developed either by resting the petcock on the carbs and running the bike (vibration with bowl sitting on carbs), or maybe by putting too much downward pressure on the tank when installing it (while petcock bowl is making contact with the carbs).  Either way it was an unfortunate surprise to see all that fuel leaving out all over the engine!
I'm more careful with it now that I replaced the bowl and gasket.  I think I paid about $15 on eBay for brand new replacements.
Mine is a 750K3.
Aaron
CB750K3 with F1 frame/swingarm
Offline ericmu17
« Reply #8 on: August 20, 2012, 02:23:44 PM »
LOL  :P
This bike is a trip! Its a 73 CB500 with 15,500k on it that I just got a few weeks ago for $300. Its been one thing after another... but im enjoying it. Ive learned sooo much from this forum about these bikes. Neat machines.... but they do take a bit of work to get them road worthy and running well after they have been sitting for a few years.
The whole petcock was rusty and shtuff... I cleaned it the best i could... but i figured for 30 bucks new why not.
« Last Edit: August 20, 2012, 02:28:26 PM by ericmu17 »
Offline kerryb
  • Not a very
« Reply #9 on: August 20, 2012, 04:16:13 PM »
ooooh...nice looking bike.  You will be rewarded with a fine machine when you are done going through all the little details.  I thoroughly enjoy my 550.  It is the only one in the fleet with four pipes still on it and they make the neatest sound.  I don't even mind the patches in them.
Offline ericmu17
« Reply #10 on: August 20, 2012, 06:49:08 PM »
I like it!!! ... I might send the oem one back and get that one!!
Offline ericmu17
« Reply #11 on: August 20, 2012, 06:52:29 PM »
Wait its just the bowl.... but I might consider it in the future
Offline fmctm1sw
« Reply #12 on: August 20, 2012, 06:54:05 PM »
huh,  I was thinking that was one hell of a big main jet when I saw it...   ;D
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #13 on: October 06, 2013, 11:11:47 AM »
Same here. Hole in the bowl.
The tank look very clean inside without rust. Maybe an acid cleaner that had reached the petcock corroded the bowl??? I do not know since I bought the old tank last year.
Good idea to replace the entire petcock with it's o-rings.
I replaced the old philips screws with allen heads.
Offline lucky
« Reply #14 on: October 06, 2013, 11:56:39 AM »
This is a common defect on this part.
« Reply #15 on: October 06, 2013, 12:32:08 PM »
Is there enough metal left to drill and tap it for a drain screw with a gasket on it?
« Reply #16 on: October 17, 2013, 10:57:28 AM »
Yes, I think it is possible to make a quick fix with a screw + gasket, fiber washer or fuel resistant glue. But the bowl is thin around the bottom and not reliable.
I had a new petcock home I could take the bowl from so the choice was easy. I had new screws too, but found that allen screws are better to tighten than the soon slipping Philips X-heads.
