Author Topic: Rust on chrome and rims  (Read 8238 times)
Offline Schnell
« on: August 29, 2012, 04:25:34 PM »
So I'm beginning to clean up my new to me 1975 cb750 that has sat in a corner of a garage for the last 10 years. I went over it (fenders, turn signal stalks, rims) with wd40 and fine steel wool. Some of the rust spots come off, but many are just too deep. Tomorrow ill go a bit deeper with a brass brush on an electric drill. What's the best way to deal with this corrosion? Paint doesn't stick well to chrome, does it?
« Last Edit: August 29, 2012, 04:49:22 PM by Schnell »
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline OldSchool_IsCool
  • Really feeling like an
Re: Rust on chrome and rims
« Reply #1 on: August 29, 2012, 05:03:26 PM »
STEP AWAY FROM THE DRILL!!
Brass brush is OK, but use the toothbrush type of brush.  Mother's chrome polish or a very fine finishing compound on the brush will do.  When you get a half wheel done, reward yourself with a refreshing cold one!
By the way, welcome to the forum and that's a sweet looking K5 you got there!
« Last Edit: August 29, 2012, 05:12:11 PM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline afkrejci90
« Reply #2 on: August 29, 2012, 05:16:43 PM »
Would CLR work?  That on a toothbrush would should seem to work.
« Last Edit: August 29, 2012, 06:50:57 PM by afkrejci90 »
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline wvshooter
« Reply #3 on: August 29, 2012, 06:45:55 PM »
I have the same problem on both of my wheels. The rust isn't horrible but it's beyond trying to clean up. Also, when I got the tire and the tube off I discovered an unacceptable amount of rust on the inside of the wheel.
I had planned on painting mine from the get go but the rust makes it a no brainer. And yes you can paint chrome. I havn't read up on it yet but I think it involves a self etching primer. Mine will get a good going over with the wire wheel, then some sanding , followed by a rust converter, followed by the best technique for painting chrome. This has been done alot by others and the results look nice assuming you don't have to have chrome.
Lastly, some of the spoke ends on the inside of the wheel had an unacceptable amount of rust so we get a new set! Whoopee!
Offline DJ_AX
« Reply #4 on: August 29, 2012, 07:07:54 PM »
Aluminum foil with wd40 is one of my favorite combos for rusty chrome.
I've got some other "Chrome Polish" stuff for the chrome which seems to work more like a waxing... haze on, hand buff off & shine.
Mothers is great ... but I use mostly only on polished aluminum parts.
And that is indeed a very nice looking K5 :)
Offline xnoahx
  • 78 750K
« Reply #5 on: August 29, 2012, 11:35:26 PM »
You can take a wire wheel to the inside of the rim to remove excessive rust.  I have always been a fan of steel wool for taking down surface rust on chrome.  Had pretty good results on the chrome bits on my 78 when I got it
Offline phil71
« Reply #6 on: August 30, 2012, 12:22:09 AM »
remember, when the rust is gone, it will generally not reveal chrome, but old, unplated steel. protect it somehow, or adjust your expectations a little.
Offline Magilla
  • My bike: 1976 CB750F
« Reply #7 on: August 30, 2012, 03:30:02 AM »
Simichrome is a product that I often use to clean chrome.  It's not fast but it works great.  Also I would agree to stay away from the drill. You will score the chrome and that won't come out.
To answer your question about paint on chrome, it can be done but the chrome has to be scuffed.  Paint won't stick to a smooth surface.  The problem is, if you paint chrome it will look like you "painted chrome". That is never a good look.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Schnell
« Reply #8 on: August 30, 2012, 08:23:09 AM »
Okay, here's the bike off the trailer and after 30 minutes going over the chrome with wd40 and steel wool. The bike looks great from 10 feet away as in the first picture, but close up one can see the corrosion.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #9 on: August 30, 2012, 08:29:24 AM »
That rim is too far gone in my opinion. You can still clean it up. I'd use a rust remover, phosphoric acid base. Google it. EvapoRust comes to mind.
But your finish is shot. Rust remover and chrome paint. Or a new rim.
The tires need replacing (age hardened, unsafe after 6+ years). Wouldn't take much to relace a new rim and go pretty.
« Last Edit: August 30, 2012, 08:31:39 AM by MCRider »
Offline lucky
« Reply #10 on: August 30, 2012, 08:33:33 AM »
Do not use a brass brush on steel parts!!!
Use a stainless tooth brush available at any welding supply store.
Or just use steel wool.
Brass and steel do not get along well in a corrosive environment.
Use phosphoric acid on those rusty areas. It stops the rust.
It turns iron oxide  into iron phosphate. Just a small sponge will work and leave it on for 30 minutes till the brown turns to grey. Then rinse with water and put some clear nail polish over the spot.
You can also just spray the treated area with WD40 after rinsing.
Offline lucky
« Reply #11 on: August 30, 2012, 08:35:30 AM »
I agree. Re chrome and rebuild that wheel. Put on a new tire and tube.
That is what I would do.
Offline Jasondo
« Reply #12 on: August 30, 2012, 08:58:36 AM »
My wheels looked exactly the same when I purchased my bike. I tried everything but was never satisfied. Ended up finding a powder coater that had good prices. ended up spending 70 bucks to have both rims done in a satin black. Looks awesome. Like they were brand new. Concider it next time you need to change out the tires. Thats a good time to do it.
« Reply #13 on: August 30, 2012, 08:58:57 AM »
go over the rust with 0000 steel wool dipped in blue magic metal polish.
for faster work, chuck a mothers power cone in your drill, slathered in blue magic, and go to work.
i betcha 50% of that will come off.  ;)
media blast and chrome/powder would be my last resort...
« Reply #14 on: August 30, 2012, 09:02:19 AM »
The rust will come off by several means. His problem is, then what?
« Reply #15 on: August 30, 2012, 09:06:37 AM »
he can ride around without looking like he just pulled his K out of the garden until that time where he can send his rims out to be properly finished   ;)  winter will be upon us soon  ;D
« Reply #16 on: August 30, 2012, 09:26:28 AM »
Yes, good plan. Ride while the sun shines!
« Reply #17 on: August 30, 2012, 09:44:45 AM »
new tires first, please ;D
« Reply #18 on: August 30, 2012, 09:49:01 AM »
Oh yeah, that too.  :D
oldbob
« Reply #19 on: August 30, 2012, 12:37:41 PM »
When I pulled the tires off of my CB400F, I found an impressive amount of rust on the inside surface of the rims. I wire-brushed and then primed the inside, but I don't know if the rims may have lost too much metal. The quote from Buchanan's for new aluminum rims and ss spokes was not insignificant, but I might go that route.
Bob
Offline Schnell
« Reply #20 on: August 31, 2012, 07:55:19 AM »
It's amazing what elbow grease, wd40, a scotchbright pad, and a mini wire brush can do. Sure, there are now areas where the chrome is pitted and micro-scratched, but there is no more rust on the chrome including the rims which looked quite dire.
Pleased.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #21 on: August 31, 2012, 01:32:45 PM »
If ur happy with 'em, that's all tat matters.  Wax 'em up good else you'll be putting more elbow grease into it again way too soon!  On to other things, like getting her running well, new rubber, and many smiles per gallon!
Sure.
Is it hard?
Offline Schnell
« Reply #22 on: August 31, 2012, 05:03:49 PM »
Applied Mothers metal polish: shines and protects.
I'm finishing this riding season on my 1976 BMW. Next spring this Honda will have new tires, euro bars, insurance, and license sticker. :)
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #23 on: August 31, 2012, 05:11:03 PM »
I would start shopping for new rims. Rechroming would be expensive.
Offline Schnell
« Reply #24 on: August 31, 2012, 05:31:27 PM »
It's a matter of personal taste and style (and finances). I'm okay with respecting the bike's age and do not need everything to look new and shiny (as long as safety is not compromised). Its going to stay a stock bike, with just the lower handlebars. Just like I'm okay with the grey in my hair and beard. I understand that this is not everyone's taste for motorcycles. Thats okay.
As I mentioned, the rust came off and just the chrome plating was affected. Cosmetics.
« Last Edit: August 31, 2012, 06:12:07 PM by Schnell »
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
