Author Topic: rebuilding 550F carburators  (Read 4723 times)
Offline jason41987
« on: September 11, 2012, 01:47:26 PM »
while im waiting on a new battery and plugs for my ignition system and electrics, i decided to pull the carburator and take a look at it.. and for the life of me i cant seem to get the throttle lever to move more than a couple of millimeters... its TIGHT.. so ive decided its probably best to rebuild the carbs, rather than simply clean them
so.. what would the best place to get a kit to rebuild all four carbs, also, where can i get new springs for the outside of the carb?... and before i put it back together... what would your recommendations be to cleaning up the metal on these? just clean and polish? or should i take it further?
Re: rebuilding 550F carburators
« Reply #1 on: September 11, 2012, 01:59:46 PM »
ultrasonic clean in simple green is a fast and effective way to get them clean.
no need to take them off the rack and separate them.  do one carb at a time. just remove the bowls, jets and emulsion tubes. clean them, put them back in the way they came out. spray carb cleaner and compressed air through all the passages
clean them well the first time.
set the float heights, and do a bench sync.
the return spring is supposed to be tight.  its a safety feature.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #2 on: September 11, 2012, 02:04:14 PM »
+1 on Simple Green in an ultrasonic cleaner. Reuse the original jets and needles whenever possible. I just replaced the rubber parts, cleaned everything else like a man possessed, and my carbs are like new.
Offline jason41987
« Reply #3 on: September 11, 2012, 02:46:51 PM »
i dont have an ultrasonic cleaner... would a wire brush on a dremel be sufficient for cleaning off the rust?.. ill have to take them apart and clean them thoroughly right after i get some metric tools to do it with and after i get this bike running ill probably have the metal housing pieces powder coated
Offline matt mattison
« Reply #4 on: September 11, 2012, 05:09:37 PM »
Got to the autoparts store and buy carb dip. It comes in a one gallon paint can and has a dipping basket. I would advise against the steel wire  brush on any cast aluminium parts. If you insist on the wire brush only use brass there. And you can also scrub the bodies down with #0000 steel wool if you wish. Chase all the passages with a guitar string and blow it out with compressed air. Re assemble.
1975 CB550F
2011 MV Agusta Brutale 1090RR
Offline jason41987
« Reply #5 on: September 11, 2012, 07:00:05 PM »
im going to try to find some reviews on "carb dip"... as for brushing to clean the carbs i was referring to the outside surfaces, to get the bits of surface rust off and make the carbs look like new as well
when i clean these, should i get a rebuild kit for them as well or not worry about it?... im just trying to get the engine to start, not concerned with how well it runs just yet
Offline Ausmithe
« Reply #6 on: September 11, 2012, 07:13:10 PM »
Berrymans is a good brand of carb dip. Also, if you're going to pull your carbs for cleaning, check the rubber o-rings around your jets and especially on the T-connectors that you hook the gas lines to. Unless you know for sure that they were recently replaced, you'd be wise to have new ones on hand prior to pulling the rack.
1974 CB750
1972 CB500
Offline jason41987
« Reply #7 on: September 11, 2012, 07:32:00 PM »
when i popped the float bowl off.. the inside was caked in white... not sure if carb cleaner would clean that out?
Offline CoachDoc
« Reply #8 on: September 11, 2012, 08:05:26 PM »
I've used the Berryman's carb dip, and it does work. However, it is toxic as all getout so be sure to use some good nitrile gloves to prevent having it contact your skin, and make sure to work with EXELLENT ventilation to reduce your exposure to the vapors. BTW, Harbor Freight has decent U/S cleaners for very little $.
Offline jason41987
« Reply #9 on: September 11, 2012, 08:11:50 PM »
harborfreight has an ultrasonic cleaner that is 5 1/2 x 8 x 5 inches... would this be enough for cleaning the carbs if i pop the plate off and clean them individually?.. then polish up the large plate with my dremel?
also, how concerned should i be by this white powdery.. crud?
Offline goldarrow
  • one day, i'll be an
« Reply #10 on: September 11, 2012, 11:29:39 PM »
+1
+1
Pine sol is also good to use.  Just let your carb soak overnight and will do just fine.  I don't have ultrasonic cleaner, not planning to get one either.
CB550 K0
Offline jason41987
« Reply #11 on: September 11, 2012, 11:41:50 PM »
i think if i was going to do this more often, id get an ultrasonic cleaner.. but this is a project im planning on taking all winter to complete.. so i have time to soak carbs overnight in cleaner... once i get this bike started theyll be taken back apart so i can powder coat the exterior metal surfaces
« Reply #12 on: September 12, 2012, 01:56:39 AM »
I'd buy the rebuild kit, do it once and do it right. I prefer the Honda parts, but others have success with aftermarket as well. Don't soak the carbs overnight, follow the instructions on the can.
1975 CB550F
Offline jason41987
« Reply #13 on: September 12, 2012, 09:08:24 AM »
wheres the least expensive place to get a carb rebuild kit?... if im going to rebuild one i might as well do all four
Offline goldarrow
« Reply #14 on: September 12, 2012, 09:46:34 AM »
reuse the hardware, replace rubbers if necessary.  harborfreight o-rings, bikebandit, z1, or feebay to name a few....
CB550 K0
Offline jason41987
« Reply #15 on: September 12, 2012, 05:02:40 PM »
i seperated the carbs so theyd be easier to work with instead of moving this giant assembly of four around... also allowed me to get to the inlets where the gasoline flows into the carbs which was packed with this white crud, which seemed to have come from the fuel tank or the fuel itself, as it didnt really seem to be part of the metal, or corrosion, it just scraped away
anyway.. fully intending to replace the rubber bits, i used PB blaster and it really cleaned up this white stuff a lot... also freed up the frozen carburators and now all four carburators move freely, also, once some of this white crap was cleared away i was able to inspect the internal parts, all of which seem to be in good working order, and therefor a rebuild does not look necessary.... new gaskets and o-rings are necessary though
so... im going to get gasket material and cut my own gaskets for the top of the carbs, and managed to pry out one of the o-rings so i can take it to a local hardware store which has all of this stuff in bulk, so i can match the o-ring i have to new ones... probably take a couple of the screws in too to match them as well
im still thinking about finding some kind of dip to soak these carbs in because i still have some of the white stuff that refuses to go away, even though it doesnt seem to be part of a corossion process, atleast not nearly as bad as i thought it was... so i was wondering if the small $25 ultrasonic cleaner from harborfreight was enough to fit one of the seperated carbs?... and it would be nice to have something to drop various nuts and bolts into to bring them back to like new condition
in all.. im happy with the carbs, i think if i were to stick them on the bike now, and my ignition system was in order, the engine would start right up
so to really get the inside of these carbs into brand new condition, what would you recommend i do to clean the insides?... i can either soak them in something, get this ultrasonic cleaner, or do it manually with some sort of a brush or dremel bit.. so long as it wont harm the brass or aluminum?
Offline jason41987
« Reply #16 on: September 12, 2012, 06:02:07 PM »
this hardware store sells everything, in metric and sae, ive purchased o-rings from them before... so im not worried about not finding what i need.. but out of curiosity, do you have a link to a place that sells those gasket kits?..
still though, i wont change any gaskets until i get the inside of that carb really clean, and get rid of the crud thats already in there.. im not sure i want to start running the engine and having bits of that stuff flake off and go into the cylinders
so.. im looking for a good recommendation on really getting the inside of it clean.. im starting to think i might have to take the manual approach with a dremel using a polishing wheel, or nylon brush.. but if theres something i can soak it in thatll do clean it all off, im all open to it
Offline jason41987
« Reply #17 on: September 12, 2012, 10:33:06 PM »
im well aware of the different materials used and the chemical properties of those materials, they have the o-rings i need in the sizes i need them.. im more worried about getting the remaining crud out of the inside of the carburator first before i put in new o-rings
Offline jason41987
« Reply #18 on: September 12, 2012, 10:51:37 PM »
does anyone have a photo of the inside of the carburetor with the float bowl removed?
Offline brewsky
« Reply #19 on: September 13, 2012, 02:03:54 AM »
The "white stuff" is almost certainly zinc oxide.  The carb bodies are an alloy of various metals including Zinc.  So, the white stuff is corrosion, brought on from exposure to oxygen and water as catalyst.
Good luck on making bowl gaskets (they were originally really large orings, and finding metric orings that are fuel proof rather than water proof at the local hardware store would be a "special find".
Here's the Honda gasket set, which has everything you need for one carb.
What about the fiber or ?? washers that "seal" the choke and throttle shafts? I assume they are not in the kits? They are held in by dimpled retainers. They probably wouldn't hold up in a dunk in commercial carb cleaners?
Can/should they be replaced with o-rings?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline andrewk
  • doin' it.
« Reply #20 on: September 13, 2012, 05:26:18 AM »
Unless you live next door to mcmaster carr, the hardware store will not have the o-rings you need.  Honda uses a lot of fractional (in between nominal sizes that a hardware store would carry) so you'll either be fiddlef*cking around with removing minute bits of rubber to get things to fit well, or you'll not have a seal at all which defeats the purpose.
Motorcycling isn't a cheap endeavor, unless you'd rather spend your time dicking with half-rebuild carbs that will never run right.
Gasket sets from honda can be had for ~12 bucks each.  Only includes the gaskets, if the needle valves are shot those are seperate parts.
These are things most people only learn from experience. You've got a wealth of information presented in front of you here, I would use it.
Good luck.
Offline Ausmithe
« Reply #21 on: September 13, 2012, 05:42:52 AM »
+1 On using the Honda kit. I've used the cheap kits you'll find on eBay and they are very close, but just off enough to make it a huge pain in the butt to get that bowl gasket to fit. You can lay them side by side with the Honda bowl gasket and the difference is hard to notice but it's enough to cause problems. And that's just in reference to size. I don't want to imagine the headache if you end up with a gasket that starts breaking down on you because it's not fully suitable for use with petrol.
1974 CB750
1972 CB500
Offline jason41987
« Reply #22 on: September 13, 2012, 12:33:51 PM »
i got some brass dremel brushes to remove the caked on white stuff... and im going to use the cheapest o-rings i can find to reassemble the carbs.. i dont care if these seals dont last long, i only need to verify the engine will start, at which point ill do a complete rebuild with all new springs, jets, needles, o-rings, gaskets, etc.. or another option im weighing is buy a set of new mikuni carbs
are the mikuni carbs any better than the stock carbs?.. if so, what makes them better, and do they deliver any performance boost or better fuel economy over the old ones?
Offline DEL
« Reply #23 on: September 13, 2012, 12:54:21 PM »
Jason:
I haven't read every word of all the responses to your questions but I am concerned about dunking ( submerging) your carbs in carb cleaner. I will be rebuilding the carbs on my 1978 GL1000 soon and have purchased the gasket kits and "how to" video from Randall Washington - "Randakk" the GL1000 guru. He specifically warns about NOT dunking the carbs  in carb cleaner. This action will destroy the felts in the GL carbs as well as removing any of the factory finish left on the outside of the carb bodies. His suggestion is to disassemble and clean with brake cleaner and use very little actual carb cleaner and on only the small brass jets, tubes etc. I would imagine this would be good advice to follow with the 550 carbs as well.
David
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #24 on: September 13, 2012, 04:10:23 PM »
Hmmm you came here asking for advice from experienced members and now you're ignoring it. We've all been through this before. Buy the Honda kits and be done with it. Do you know for sure if the motor turns? If so then there is probably not a lot wrong with it that can't be fixed for fairly cheap. It might need a top end maybe even new rings, thats not the end of the world. Then you know what you got in the motor. But don't skimp now it will only cause you headaches later. Like I said we've all been there.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
