Author Topic: 2-3 firing at different positions relative to TDC and I don't know why  (Read 529 times)
Offline gregimotis
  • poet laureate; SOHC4.
Using a timing light, I can get 1-4 timed perfectly but the 2-3 strobes once at one position and then at another position one or two degrees to the clockwise. It alternates and I can't imagine why.
Additionally, when the light is measuring the #3 wire (haven't yet tried the #2), it fails to flash every six or eighth time.
Offline Old Scrambler
Re: 2-3 firing at different positions relative to TDC and I don't know why
« Reply #1 on: September 23, 2012, 04:05:32 PM »
Before we get into the very remote possibilities.........check your timing light connections...........then check to make sure the points-base is tight on the 2-3 side......If new points, check to make sure the felt is greased.....and first or last, check the true-ness of the centering bolt to the crank.......if it wobbles the slightest bit, it will give you that 1 or 2 degree difference........search for the HONDAMAN cure for the wobble.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
