Author Topic: engine removal process 1 Or 2 person  (Read 12697 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: September 29, 2012, 04:34:16 PM »
I've seen a few stories and videos about people taking out an engine with 1 or 2 people by laying on its side.
my first question is does this work that well if you're trying to keep the engine undamaged?
what is the procedure for doing this the correct way? What tools do I need? what bolts do i take out ?
can you do the same thing to put in a motor? I'm doing a swap.
I need some information I guess.
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Dyrden
Re: engine removal process 1 Or 2 person
« Reply #1 on: September 29, 2012, 04:59:33 PM »
If you can get 4 hands on it, youll no doubt save lots of time, especially the first time around.  If your engine uses exhaust studs, taking them out can actually save time(or cost you a bunch if you break one).  Also the engine is pretty damn heavy, even if you get it out by yourself its a bear to handle alone when its fully assembled.  I used the "lay the frame on the side" technique to pull the engine and am building it in the frame(using a gordons kit allows this)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: September 29, 2012, 05:12:44 PM »
So for hands and the side method?
Gus, Austin, MN.
Offline DJ_AX
« Reply #3 on: September 29, 2012, 05:57:45 PM »
I recently took my engine out while the wheels were still on.
I wrapped some slings around the sides of the engine  to a 5' long 2 x 4 just behind the valve cover.
on the left side the board extended  a few feet, the end of it up on a couple of milk crates.
The other end of the board, I hung from above with one of those cheap tie down winches.
Snugged it up. Cranked the winch just a bit, tilted the engine, and then dragged the bike away.
Slide another milk crate under the engine and set it down.
I could have done it by myself but my wife helped a bit :)
Offline wvshooter
« Reply #4 on: September 29, 2012, 06:20:01 PM »
If you're really concerned about engine or frame damage or personal injury you should probably go with something mechanical that can support the engine from above.
A few years ago I removed and reinstalled the engine in a 750 two different times. Did it alone but rigged an awkward hoist from the ceiling. It wasn't easy to say the least. Sold that bike and now have another 750. Just removed the engine on the new bike but couldn't bring myself to do it the hard way. Solution...
Bought an engine hoist from Harbor Freight, $150. Spent half a day welding up a simple c frame type jig out of 1 1/2 x 1 1/2 rectangular steel tubing, $20. The jig attaches to the hoist above the center of the bike frame. The jig reaches around the center of the frame and extends under the frame so both sides of the engine can be grabbed using straps like the ones found on tie downs.
Removing the engine with this thing could not have been easier. And didn't need a helper. No lifting. No possibility of injury. No damage to anything. I had done it the scary way before and didn't want to go there again.
« Last Edit: September 29, 2012, 06:22:00 PM by wvshooter »
Offline JohnG
  • 1976 CB750F - original owner
« Reply #5 on: September 29, 2012, 07:32:58 PM »
I have an F so I don't know if that helps or hurts - probably neither.  Have had the motor in and out a dozen times in it's life.  The F has exhaust studs, certainly no asset.
Best move I made was to use a small, foreign car scisssors style jack and a long, heavy duty flat blade screwdriver.  Once the last bolt is out, the last few times it has taken about 5-10 minutes to get the engine out.  I put it on a milk carton.  The jack and screwdriver allow me to strategically move things but still have both hands free.  The jack also helps on the way back in.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline lucky
« Reply #6 on: September 30, 2012, 03:15:40 AM »
I am 63 and I have taken the CB750 engine in and out of the frame by myself with almost no effort while the frame and engine are laying on its side.
Remove the rear wheel. Remove the front wheel.
The more you take off the easier it is.
Best to have everything off.  Just the frame and the engine.
Make sure you have it laying on the correct side for removal.
The engine on the CB750 is made to come OUT of the right side of the motorcycle.
So to REMOVE the engine, lay the bike on its right side. Put it on a thick folded up sleeping bag or old mattress etc., to protect the engine.
If you have a oil pressure gauge on... it REMOVE that or it can get broken.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #7 on: September 30, 2012, 05:47:06 AM »
How many bolts do you leave in before you tip it?
Gus, Austin, MN.
Offline KC_Northstar
« Reply #8 on: September 30, 2012, 06:11:12 AM »
Here is how I did it.  Just one person and was really pretty easy.
http://forums.sohc4.net/index.php?topic=102658.0
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline lucky
« Reply #9 on: September 30, 2012, 05:19:30 PM »
Two.
The bottom rear and the top rear.
Offline killersoundz
« Reply #10 on: September 30, 2012, 05:38:43 PM »
I remove all the motor mounts. Lay down some padding on the floor. Kick the s.o.b over on to the pads. work the frame off the motor
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Offline lucky
« Reply #11 on: October 01, 2012, 07:37:27 AM »
No..Lay it over carefully.
Make SURE the oil filter is off and the top breather cover on top of the engine. That small cover held on with three screws.
Before laying it over.
THEN pull the bolts out of the engine.
Now stand over the top and look at how the engine is still in the mounts.
Turn the frame just a little until you see the mounts clear the frame lugs and gently lift up the frame.
Offline DJ_AX
« Reply #12 on: October 01, 2012, 10:12:26 AM »
...Turn the frame just a little...
clockwise :)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #13 on: October 01, 2012, 07:13:10 PM »
Then can you do the same putting it back in?
Gus, Austin, MN.
Offline Pecantree
« Reply #14 on: October 01, 2012, 09:04:02 PM »
First time I ever pulled the engine on the 750 I used the pole thru the frame method.
It's been posted several times previously.
It was easy and did it solo.
At the end landed the engine on a 4 wheeler with a plywood platform screwed to it.
Still had a rolling chassis too!
Seems like it would be easier than laying the bike over.
Good luck however you go!
Steve
PS. Like Hondaman say's, grind that little tab  off the bottom right rail.
« Last Edit: October 01, 2012, 09:10:43 PM by Pecantree »
« Reply #15 on: October 01, 2012, 10:32:46 PM »
Where DO you guys find all these nice milk crates?  ;D
Offline 72 yellow
« Reply #16 on: October 02, 2012, 07:23:37 AM »
It helps if you live near a grocery store  ;)
Offline DJ_AX
« Reply #17 on: October 02, 2012, 09:22:16 AM »
We use 'em for stacking ;)
Offline fang
    • Food Renegade
« Reply #18 on: October 02, 2012, 10:06:47 AM »
Quote from: DJ_AX link
OMG I LOVE those pics!
I used to be a climbing guide, mostly all over Texas.  I've worked in most of the gyms in Texas as a out setter and lead instructor....
But I rarely seen anything as cool/silly/crazy/fun as that!
Kudos to you.
As far a s removing the motor, I really like seeing pics of the pole method, as demonstrated by Pecantree.  I have never tried that way, and it looks like a good one.
In light of everyone saying how easy it is to remove a motor, remember that it still is pretty hard -- and people can get hurt easily!
Also, if you're not very careful, it is very easy to scratch up your frame.  I usually will tape up some cardboard to the frame tubes to protect the finish of the frame AND the motor.
Peace and grease,
steve
« Last Edit: October 02, 2012, 10:09:31 AM by fang »
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
Online kerryb
  • Not a very
« Reply #19 on: October 02, 2012, 01:19:11 PM »
look Ma!...one hand!
Cable goes to a harbor freight hoist in the rafters.
Offline lucky
« Reply #20 on: October 03, 2012, 09:41:33 AM »
YES.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #21 on: October 03, 2012, 07:29:59 PM »
Steve
This is the way im going to do it. Awesome idea!
Gus, Austin, MN.
« Reply #22 on: October 03, 2012, 08:58:16 PM »
if you have something to hang a cheap chain hoist from, that and a small nylon strap will pop one right out.
