Author Topic: Winter "to-do" list for the Honda?  (Read 989 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
« on: October 04, 2012, 08:56:21 AM »
Anybody else have a to-do list they're waiting for winter to tear into? At the moment the weather has been fantastic here in the Pacific northwest and I am too into riding to be wrenching. Although the bike needs some attention it still runs and rides fine. This is kind of the opposite of "What did you do to your bike today" thread.
First on the list:
Clean the carbs again. I've noticed the bike getting harder to start and warm up. After seeing what E-10 fuel does after sitting just a couple of weeks I assume the pilot jets are getting clogged. It runs fine once warmed up. I just did a basic tune-up: new plugs, points, timing, valves, cam-chain tension. So a complete carb cleaning is in order when the weather is too crappy to enjoy riding.
Second:
Front end tear down. Fork seals are leaking. Lesson learned on aftermarket crap. It will be OEM next time. And while I have the front end a part I plan on taking the rotor in to be drilled and surfaced a bit. And new pads. And if I can find a front fender in better condition than mine I will replace that too.
Third.
One last oil leak from under the chain cover. So far I've replaced the shifter shaft seal, the output shaft seal, so the only thing left is the oil pump seals. I have the o-ring set just waiting for the time to put them in. That will be during the next oil change.
And that should that, winterize it and wait for next spring.
« Last Edit: October 04, 2012, 08:59:02 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline jason41987
Re: Winter "to-do" list for the Honda?
« Reply #1 on: October 04, 2012, 08:58:01 AM »
i have you beat, i have to tear down the entire bike this winter and rebuild from the frame up... but it gives me something to do
Offline mono
  • Definitely no
« Reply #2 on: October 04, 2012, 09:18:42 AM »
on the 550:
- fork rebuild
- install tapered bearings
- electronic ignition (or maybe HondaMan, still on the fence)
- brake caliper rebuild (new piston, no big deal)
- clean + rejet the carbs
- new brake lines
on the 750C i'm doing a full teardown/overhaul.  aside from the standard painting/polishing:
- finishing front wheel swap from comstar to spokes w/ dual disc
- tank liner
- carb rebuild
- fabricating some additional custom parts
- full brake rebuild (rebuild calipers, replace lines, rebuild MC)
- etc etc etc.
« Last Edit: October 04, 2012, 11:49:04 AM by mono »
Offline singedebile
« Reply #3 on: October 04, 2012, 10:00:37 AM »
550f0
-Clean the Carbs for the first time in the 3 years I've had the bike
-Install cb650 cam and replace cam chain/cam tensioner
-Build new headlight ears (old ones are too far gone)
-Paint/cleanup 'new' exhaust and install
-'new' stock sized rear wheel and tire
-install Raask rearsets
-Dual disk front??
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
« Reply #4 on: October 04, 2012, 10:47:22 AM »
yep:
on the list..
engine....RTV was used by the PO, so teardown is needed, eventually.
new gaskets all around - valve cover gasket leak over #3 - stripped valve cover bolt needs helicoil.
dual front rotor setup/forks/trees.  have rotor(s) cross drilled.
(cant figure out why my bars continually cant to the right. ive tried everything)
lossa/coneeng reverse cone muffler.
HID headlamp conversion
trim rear fender shorter, rotate up under seat, new(brighter) brake light.
vinegar tank treatment, new fuel tap.
motor starts well and runs like a champ, except for the slight valve cover oil leak and the RTV gasket material showing.  i dare not pick it out as its probably holding me together, thanks ufcking PO, whoever you are ::)  might make it another year before a total rebuld is needed.
we'll see what actually gets done...
