Author Topic: Where to get replacement carburetor part (CB350F)  (Read 1198 times)
Offline Dynamo
« on: October 15, 2012, 08:31:11 AM »
It appears I have lost that little cylinder that goes between carb 2 and 3. It is what the spring latches on to, to keep tension on the throttle pulley(wrong name but cant remember what it is called). For a clearer explanation it is DIRECTLY below #17 on this diagram.
http://www.mrcycles.com/fiche_section_detail.asp?section=2140582&category=MOTORCYCLES&make=HONDA&year=1974&fveh=124959#.UHwpCxjrh9Y
It is an unmarked piece. Anyone have a clue on how I can get another one of these? I tried just hooking the spring to one of the vacuum line tubes, but I don't think its providing enough tension.
1973 Honda CB350F
Offline Dynamo
Re: Where to get replacement carburetor part (CB350F)
« Reply #1 on: October 15, 2012, 12:17:36 PM »
Nobody knows:(?
1973 Honda CB350F
oldbob
« Reply #2 on: October 15, 2012, 02:39:26 PM »
I looked at my spare set of carburetors, but it turns out they too are missing that part. Why not just cut a piece of steel rod (or even a bolt) to the correct length and call it good?
Bob
Offline davis96
« Reply #3 on: October 15, 2012, 08:46:22 PM »
Bob
+1
I mean it is just a cylindrical piece of steel, could be replaced by just about anything with the right dimensions
'74 CB350F - sold
'71 CB500K
Offline Dynamo
« Reply #4 on: October 18, 2012, 02:24:22 PM »
I hear what you guys are saying..and I like it. I have been super scatterbrained lately, I could just cut down a nail or something and get it right in there.
1973 Honda CB350F
Offline tomkimberly
« Reply #5 on: October 18, 2012, 04:00:03 PM »
Go to the hardware store and pick up a few dowel pins.
One thing to consider, this part not only secures the bottom hook of the return spring, it also sets the spacing between carbs 2 and 3.
Tom
« Reply #6 on: October 19, 2012, 03:07:30 AM »
If its the same as the 500 its part number 16066-323-004 NOTE: the spring and cover are 500 parts
Offline 72_350_FOUR
« Reply #7 on: October 19, 2012, 05:51:00 AM »
I'm pretty sure i have one at home, i can check tonight.   I have a 2nd set of old carbs, that have come in real handy, i've picked more than one or two parts of of them.
1972 Honda CB350F
