Author Topic: steel friction plate.....which side outside ?  (Read 3497 times)
Offline skassakaxxo
« on: October 20, 2012, 01:58:26 PM »
i have to change friction plates on my 500 and 750 ....
can someone tell me in which way i have to put the steel plate....???
i see that the steel plate has difference.... one side is straight/ flat and one side is curved/roundend
on 500 and 750 four the rounded side go inside and the straight go out?
there is no info on the service manual about it.....
Offline Bailgang
  • Scott
  • Indiana
Re: steel friction plate.....which side outside ?
« Reply #1 on: October 20, 2012, 03:10:23 PM »
I hope someone will correct me if I'm wrong but I don't think it matters so long as all of them are facing the same way say for instance you install the first steel plate with the sharp edged face facing the engine then install the rest the same.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #2 on: October 20, 2012, 03:21:50 PM »
what bailgang said,just stack them all the same way,deglaze the steels first and soak the new frictions in oil overnight at least.
Offline Magpie
« Reply #3 on: October 20, 2012, 05:15:02 PM »
Smooth edge side to the outside. Read that somewhere on the forum. Hondaman? Cliff.
Offline skassakaxxo
« Reply #4 on: October 20, 2012, 11:52:28 PM »
thanks for info.... i know that they need to be placed with the same side.... but my doubt is if  the sharp side is inside motor or outside.....
« Reply #5 on: October 21, 2012, 12:23:04 AM »
the direction dosent matter,its the tension within the pressing being aligned,,it probably makes two fifths of #$%* all difference anyway,just an attention to detail thing,its only a disc being squished that technically should be flat both sides,the edge isnt load bearing.
« Last Edit: October 21, 2012, 12:25:39 AM by dave500 »
Offline skassakaxxo
« Reply #6 on: October 21, 2012, 04:12:00 AM »
ok.... i see ........ last question..... each 500 four steel plate has a notch....they need to be alternate or i have to put them with the notch aligned?
Offline lucky
« Reply #7 on: October 21, 2012, 11:35:17 AM »
Rounded edge of the steel stamped plate faces out towards the mechanic.
Offline skassakaxxo
« Reply #8 on: October 21, 2012, 12:11:00 PM »
at this time i'm not sure of nothing..... mmmmmm
« Reply #9 on: October 21, 2012, 12:40:08 PM »
i line those notches up.
Offline lucky
« Reply #10 on: October 21, 2012, 01:28:36 PM »
Why come to the forum?
« Reply #11 on: October 21, 2012, 10:54:25 PM »
with your 500 check the basket end float,there is a shim washer under that circlip,you may need to add another if its sloppy,you have the workshop manual for both bikes?
Offline skassakaxxo
« Reply #12 on: October 22, 2012, 05:34:55 AM »
@ lucky what i said before due to the different of answers got ....
someone said the round edge go inside....you said it go outside (toward the mechanic).....
aniway i have the manual for both bikes... i now that i need to put a washer but my question is
all the steel plate need to be placed with the notch (arrow in the photo) in the same way or their position is not important?
i dont' speak english so my question probably are not easily understand......sorry for this....
Offline lucky
« Reply #13 on: October 22, 2012, 06:41:33 AM »
It is very important to look closely at things that we take apart and write little notes if needed as we take it apart.
All of the notches in those clutch metal plates are the same.
« Reply #14 on: October 22, 2012, 12:44:44 PM »
line the notches up together,its good to note how things come apart like lucky said ,however sometimes because these bikes are so old and may have been apart a few times over the years by anyone they can sometimes have been assembled incorrectly or missing small pieces,study your manual aswell.
Offline skassakaxxo
« Reply #15 on: October 22, 2012, 12:59:14 PM »
you're answer would be 100% right if i was sure that previous owners did everything carefully or if i had a bike 100% never used.....
unfortunately this for me has not yet happen
the problem is when you get bike used by guys that don't follow manual or put pieces inside in random way.....
