Author Topic: Purple Rain Bill's CB750/900 Turbo 1972  (Read 60663 times)
Offline TurboD
Re: Purple Rain Bill's CB750/900 Turbo 1972
« Reply #150 on: August 25, 2015, 04:54:56 AM »
That's not pretty for sure. :(
Lets keep in mind, the primary causes of detonation is lack of fuel quality and or too much timing. I would not be quick to blame the ignition system or boost level.
A simple easy way to reduce the timing is to limit how much the advancer advances. I usually shoot for about 8-9 degrees off the total.
« Reply #151 on: August 25, 2015, 05:25:21 AM »
Wow Bill, nice ashtray!  That won't buff out.  Did it tear up the liner?
Mike, Dragbike wouldn't have any say so about the track.  On top of problems I mentioned, the right lane timing light at 1000' was not operating.  This same friend said the track owner does very little maintenance.  I would guess the track personnel are not to concerned with accuracy in the timing system.  IF that is the case, it makes it very hard to dial in a vehicle.
I understand that Dave  ;).....I figured Dragbike may be able to make those problems more public knowledge. At that point maybe the owner tries to clean things up. Or maybe he doesn't. ;D
 Bracket racing is all about measuring time. Somebody should get on somebody's a$$ about it.
« Reply #152 on: August 25, 2015, 08:54:19 AM »
Rough luck Bill. As TurboD says we've all heard stories about inconsistent fuel quality and that's something to be mindful of. Best to remove any & all sources of bad luck inducers though!! Good luck forward.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #153 on: August 25, 2015, 09:13:26 AM »
All ignition based problem, no retard with too much boost. 5-6 lbs would have been fine, 17-20+, not so good. We going with more cc and more boost! WTF? We going in the 9'$!!!!!! No typo error, it's going to happen! $tay  tuned!
Fuel was VP C16, not the problem. Got me a nice expensive ashtray! ! See y'all at Valdosta in the 10's for sure....both bikes!  ;D, Bill
BentON Racing Website
BentON Racing Facebook
Offline BPellerine
« Reply #154 on: August 25, 2015, 12:24:58 PM »
old school 900 pistons?sure sucks!billp
1978 CB 750K ard and webers
another anfob
Offline kmb69
« Reply #155 on: August 25, 2015, 12:28:36 PM »
Offline TurboD
« Reply #156 on: August 25, 2015, 01:03:25 PM »
I would like to add to my comment above.
*Lets keep in mind, the primary causes of detonation is lack of fuel quality, *lean fuel mixture* and or too much timing. I would not be quick to blame the ignition system or boost level.*
Bill A couple things to consider. The ATP intake is very small, the outer 2 cylinders often times will be leaner than the center 2. And you do not need a boost retard if you reduce and limit the timing. I have ran bikes up to 35 lbs of boost without any problems with a VERY basic ignition. The key is limiting the timing.
Online scottly
« Reply #158 on: August 25, 2015, 06:24:34 PM »
Bill, please check the ring end gap on the surviving cylinders.
    • BentON Racing
« Reply #159 on: August 25, 2015, 07:46:59 PM »
Mike, I'll take em. No retard, too much boost, and too lean because of no fuel pressure to keep bowl full, old school 44mm Kehein carb. Swapping out carb, installing pump @ 4 psi. Dyna 4000, with boost retard box, 2 step, replacing log manifold ex, with the newer style 4-1 ,the separate power pulses spool up turbo quicker. Got plans for Pro ET and Super Eliminater class. Bill
Offline dragracer
  • CB750F Dragbike
« Reply #160 on: August 26, 2015, 10:42:08 AM »
Bill, we'll get that Dyna 4000 hooked up and the retard box wired to pull timing. This bike is going to make some safe power the next time it comes out!!!!!!!!!!!
Offline TurboD
« Reply #161 on: August 26, 2015, 11:57:29 AM »
Bill if you do not have a fuel pump on the bike, this is the problem that caused the meltdown. There is no way that a single float bowl, single needle and seat with gravity feed will keep up with anything over a few pounds of boost. A lot of pressure is not needed, 2-2.5 lbs of fuel pressure will keep up. Too much pressure and the needle and seat cannot deal with it.
Many of the changes you listed are not needed. The 44mm carb is already larger than the turbo inlet. It is unlikely that changing the exhaust will help as well, A small engine (<1100cc) will spool better keeping the exhaust size in check.
In the past with Kawasaki's we have made 280 rwhp with these old single carb setups using very basic electronics.
    • BentON Racing
« Reply #162 on: August 26, 2015, 01:35:19 PM »
D, keep info coming. Carb size is fine, not adjustable as later Bendiix Zenith ones. Of course it ran out. Why we wanted to run 5-6 lbs with std or slightly retarded timing. You really think a young gun is going be watching the gauge? Not anyone's fault but mine, I knew what would happen....did!  ::) ;D. Exhaust not bigger, different design from Bill Hahn ,the creator. He probably knew what he was doing.  ;) ;D.  I'm going to keep it as simple as I can. Keep up with the input, I appreciate it!  Bill
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #163 on: August 26, 2015, 01:55:37 PM »
Ah, I really can't wait to ride this purple rocket again!
« Last Edit: August 26, 2015, 01:57:19 PM by TreyAllen »
Offline dragracer
  • CB750F Dragbike
« Reply #164 on: August 26, 2015, 04:25:14 PM »
We're going to keep you off the straight away over 1/4 mile though. Lol.
    • BentON Racing
« Reply #165 on: August 26, 2015, 04:39:28 PM »
Yeh, that test ride was a little long!!! My bad again,  wasn't specific enough! We'll get it though, stay tuned, Bill
    • BentON Racing
« Reply #166 on: August 26, 2015, 07:09:23 PM »
Trey's first pass is on YouTube. Under Trey Nalley's first pass on Bill's Turbo CB750 Purple Rain.There's 2 of them. Pleasa to download here. Then my dyno run is also there Bill's MinI Cobra 915cc 101.24 rwhp dyno run. Please post it in Calendar Girl thread and the dyno runs thread, thanks Bill  ;D The dyno run is actually the 99.98 one.
« Last Edit: August 26, 2015, 07:12:44 PM by Bill/BentON Racing »
Offline edwardmorris
  • Youngish
« Reply #167 on: August 27, 2015, 09:53:37 AM »
Here you go Bill  ;)
P1
P2
    • BentON Racing
« Reply #168 on: August 27, 2015, 11:06:55 AM »
Rafi,  thanks, Trey, next pass is in the 10's!!  ;D Bill
Offline RP
    • Restoration Paint
« Reply #169 on: August 27, 2015, 12:36:21 PM »
I am not sure Bill Hahn always knew what he was doing.  His first turbo kits for Kawasaki Z1's did not have wastegates.
Ralph
www.paintworkz.com
78 Z1R TC
84 Ninja 900
CBX Pro Stockers
CB750 Funnybike
77 KZ1000 tubo
    • BentON Racing
« Reply #170 on: August 27, 2015, 07:39:56 PM »
Yeh, they blew up a few learning!  ;D, Bill
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #171 on: August 28, 2015, 06:22:26 PM »
Bill sorry to see your sacrifice to the Aluminium Gods. Been there, done that. But once I replaced my bike's little pulse fuel pump with a Holley Red unit and adjustable regulator, the melted pistons stopped.  I ran 15 psi on ERC 110 gas but later shimmed up the barrels for lower compression. That's how the motor lived with 30+ psi boost on 118 fuel.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
    • BentON Racing
« Reply #172 on: August 28, 2015, 06:52:52 PM »
Robbie, thanks, heading that way.  970cc turbo pistons, fuel pump and regulator, Dyna 4000 ignition. It will be a better package. Bill
« Reply #173 on: August 28, 2015, 07:59:07 PM »
Robbie our turbo hero who ran 10.0 on stock pistons.... He knows a bit about it.
Offline RP
    • Restoration Paint
« Reply #174 on: August 29, 2015, 05:48:53 AM »
Even at 6 psi you need to retard the timing a bunch.  If the young gun is not watching the gauge just install a check valve and release to hold the highest reading.
Ralph
www.paintworkz.com
78 Z1R TC
84 Ninja 900
CBX Pro Stockers
CB750 Funnybike
77 KZ1000 tubo
