Bill your ring end gap is on the minimal side, but I don't see it as being a problem or your problem. I have seen many get away with far less.
That said. I am going to quote myself from my earlier post. This is the number one thing I would look at for the cause....
My Quote
"Bill if you do not have a fuel pump on the bike, this is the problem that caused the meltdown. There is no way that a single float bowl, single needle and seat with gravity feed will keep up with anything over a few pounds of boost. A lot of pressure is not needed, 2-2.5 lbs of fuel pressure will keep up. Too much pressure and the needle and seat cannot deal with it."
