Author Topic: Question about early style 750 carbs  (Read 1883 times)
Offline greenninja85
« on: November 21, 2012, 10:02:11 AM »
Does anyone know the stock needle shim position?  I know theres 6 or 7 slots where it can go but i'm not sure if mine was ever moved before I owned it.  I was assuming the very top slot would be stock but thats just a guess and I wanted to be sure.
Offline kmb69
Re: Question about early style 750 carbs
« Reply #1 on: November 21, 2012, 10:04:40 AM »
If you are talking about the 4 cable style carbs, I am pretty sure they came with the needles set in the middle, #40 slow jets, and #120 main jets.
Offline Magpie
« Reply #2 on: November 21, 2012, 10:13:04 AM »
Ditto on kmb69. My K0 and K1 carbs came with the needle set in the middle slot. Cliff.
« Reply #3 on: November 21, 2012, 11:05:15 AM »
The carbs came off a 73 cb750k.  And i'm pretty sure a 105 or a 110 main jet..can't think right now
« Reply #4 on: November 21, 2012, 11:23:04 AM »
And i'm not sure what you mean by 4 cable, theres two throttle cables on these carbs the push and pull.  Would the stock position still be the middle do you think?
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: November 21, 2012, 11:29:17 AM »
Early style carbs are usually referred to as the 1 into 4 cable models that were on the K0.  The carbs you have would be the  later style that were on the K1 through K6,  K7 and K8 had another style that utilized an accelerator pump...Larry
Offline SOHC Digger
  • I'm not an
« Reply #6 on: November 21, 2012, 08:59:18 PM »
If your carbs are 7A's, then it is the 3rd clip position down.  If they are 657B's, then it's the 4th.
« Last Edit: November 22, 2012, 10:24:16 PM by SOHC Digger »
« Reply #7 on: November 22, 2012, 10:20:46 AM »
How do I tell which one of those they are? ???
Offline harisuluv
« Reply #8 on: November 22, 2012, 01:44:28 PM »
They will be stamped about the head side above the hole.  (hope that makes sense)
« Reply #9 on: November 22, 2012, 04:23:21 PM »
Lol not really but I'm sure I'll find it. Thank you
Offline lucky
« Reply #10 on: November 23, 2012, 04:05:08 PM »
Almost ALL japanese motorcycle carbs slide needles that have adjustable needles were FIVE grooves.
Offline lucky
« Reply #11 on: November 23, 2012, 04:05:17 PM »
The 7A carbs were 3rd groove down from the top for the slide needle clip.
657A's were 4th needle groove down from the top for the clip.
If you have the 69-70 carbs you would know it.
They do have the four into one throttle cable.
They weigh less than all the other CB750 SOHC carbs.
 They are the easiest to adjust while on the bike.
« Last Edit: November 23, 2012, 04:09:42 PM by lucky »
