Author Topic: replacing spoke  (Read 1785 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
replacing spoke
« on: December 22, 2012, 01:11:05 PM »
do you have to break down the wheel to replace a broken spoke 1 ?
Offline wvshooter
Re: replacing spoke
« Reply #1 on: December 22, 2012, 01:21:33 PM »
The problem with replacing a spoke without removing the tire is the length of the replacement spoke.
Once the replacement spoke is seated in the hole in the wheel hub it's going to be too long down at the wheel rim end to get started on the spoke nut. The nut would have to be pushed deep down into the wheel rim. I'm replacing all my spokes the normal way now and just don't see how one spoke could be replaced without removing the tire and tube.
Even with the tire and tube off it may be necessary to bend the replacement spoke a little to get it to go into the rim spoke hole. All of your other spokes are going to be tightened thus holding the rim and hub in a stiff relationship which causes the problem.
« Last Edit: December 22, 2012, 01:27:30 PM by wvshooter »
Offline neilc
Re: replacing spoke
« Reply #2 on: December 23, 2012, 01:42:23 PM »
anyone know where i can get 1?
Offline sethdhawkins
Re: replacing spoke
« Reply #3 on: December 23, 2012, 01:50:38 PM »
I believe they're still an oem part, thus can be ordered from the dealer. There are also the 3-4 spoke kits that show up on eBay often. Interesting fact on spokes that I learned recently; thread pitch is different from buchannan's, those Bangkok spokes on eBay, and oem.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
bollingball
Re: replacing spoke
« Reply #4 on: December 23, 2012, 01:55:35 PM »
Post in parts wanted and say what wheel and size 17 18 19 Someone may have some old ones around. I will have some after Christmas I hope 78 750 17'' rear.
Ken
Offline neilc
Re: replacing spoke
« Reply #5 on: December 23, 2012, 02:25:16 PM »
need 1 for 19" rim
Offline wvshooter
Re: replacing spoke
« Reply #6 on: December 23, 2012, 09:32:16 PM »
need 1 for 19" rim
I've got a complete set just removed from the 19" front wheel on my 1974 750. They were replaced with a new set purchased from cb750.com
They're not rusted and clean up pretty well on a wire wheel or some other way of polishing. I'll send you a couple with spoke nuts if you can PM me. I'll need to know if you require the inside spoke or the outside spoke.
The "outside" spoke has a longer hook then the inside spoke. Also the "outside" spoke has a greater than 90* bend at the top of the spoke while the inside spoke has less than a 90* bend.
Offline neilc
Re: replacing spoke
« Reply #7 on: December 25, 2012, 08:02:27 AM »
here is a pic of the 1 i need
bollingball
Re: replacing spoke
« Reply #8 on: December 25, 2012, 08:36:20 AM »
What is that black thing? I would take and cut it at both ends if you are still riding it. Don't want that flying off at speed :o Not the best idea but with that said I have been missing one on the rear for 6000 miles not over 65mph and don't even notice a out of balance :o. Santa gave me a gift certificate today for a new set. Plus sprockets chain brakes bearings tire tube the works yea Santa ;D ;D
Ken
Fix it as soon as you can.
Offline wvshooter
Re: replacing spoke
« Reply #9 on: December 25, 2012, 09:51:41 AM »
Hey Neil, just saw the pic after sending a reply to your PM.
That's the "outside" spoke for sure. BTW, I just finished drilling my brake rotor and I'd swear the pattern I used is identical to the pattern on your bike. I think my holes may be slightly smaller. Looks nice!
Dave
Offline neilc
Re: replacing spoke
« Reply #10 on: December 25, 2012, 02:17:57 PM »
ya, the black thing is something the previous hacker owner put on to hold the 2 halfs together,the bike wont be on the road till spring but if i to break down the wheel and replace it before then
Offline tlbranth
Re: replacing spoke
« Reply #11 on: December 26, 2012, 11:08:19 AM »
I'm pretty sure I have some OEM 19" spokes. Let me know if you want one. Assuming you can get the spoke threaded through the rim and into the nipple, you could let the air out of the tube, break the bead and scooch everything over to see if you have any dangerous protrusion. Then you'd know if the tire needed to come off.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline wvshooter
Re: replacing spoke
« Reply #12 on: December 26, 2012, 01:22:12 PM »
Neil, I dropped two outside spokes with spoke nuts attached off at the post office today about 3:00. You should have them in a couple days.
Offline neilc
Re: replacing spoke
« Reply #13 on: December 26, 2012, 04:08:35 PM »
thanks wvshooter,i owe ya one
