Author Topic: Stuck tappet cover  (Read 7795 times)
Offline ncstatecamp
Stuck tappet cover
« on: January 26, 2013, 03:52:55 PM »
So I've got all the other tappet covers off ready to polish but 1 (isn't it always like that damnit!) I'm currently soaking it in pb blaster (pic). I've already gummed up the outside a bit. 17mm doesn't seem to fit all that snuggly and the vice grips slipped. I don't want to add to much heat in fear of melting the rubber seal into more of a glue. So SOHC whatcha got?
Offline fire113
Re: Stuck tappet cover
« Reply #1 on: January 26, 2013, 04:26:52 PM »
Hi ncstatecamp,
...I had the same problem for two times and I used a chisel, one punch and it was free.
Good luck...Georg
Offline phil71
« Reply #2 on: January 26, 2013, 04:29:40 PM »
you may end up smashing it, but don't worry.. they're cheap.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #3 on: January 26, 2013, 04:42:00 PM »
I used a set of Robogrips I got along time ago on the 1 (one) I had sticking. And it took it right off.The Robogrips are kind of like a Channel Lock pair of pliers.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline phil71
« Reply #4 on: January 26, 2013, 05:20:55 PM »
if the top shears off, which happens a lot, you can very easily pry the remaining threaded section out with no damage to the valve cover.
Offline ncstatecamp
Stuck tappet cover
« Reply #5 on: January 26, 2013, 05:24:27 PM »
Hi ncstatecamp,
Good luck...Georg
I'm afraid I'm not knowledgeable in this technique. Elaborate?
Offline ncstatecamp
Stuck tappet cover
« Reply #6 on: January 26, 2013, 05:25:12 PM »
It's cool I have another parts bike with 8 of em!
Offline ncstatecamp
Stuck tappet cover
« Reply #7 on: January 26, 2013, 05:27:34 PM »
For future reference once I have the bike all back together should these be low strength thread locked? I'm only asking bc my other bike recently killed its self by vibrating out the oil plug, and I'd like something like that not to happen.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: January 26, 2013, 05:48:25 PM »
They come out easy once you break em. :-)
  • 1977 CB550F2
« Reply #9 on: January 26, 2013, 05:54:00 PM »
Just screw them on lightly. I usually put some goop of some kind on them. If they leak tighten them.
Offline cbr954
« Reply #10 on: January 26, 2013, 06:22:55 PM »
No thread lock you need to be able to remove them to adjust valves.  If they leak put new o-rings on the tappet covers.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline ofreen
« Reply #11 on: January 26, 2013, 07:47:38 PM »
Get a newer Craftsman 6 sided 17mm box wrench.  The geometry of these applies the torque to the sides of the hex, not the corners.
Greg
'75 CB750F
« Reply #12 on: January 26, 2013, 08:11:16 PM »
I use a pair of channel locks but I do not put them on the 17mm nut section. I put them around the round cap outer edge section,get a good bite and give it a turn. Doing that won't break out the center of the cap and maybe drop something into the engine.Best to keep a couple of good spares around the shop.
Offline phil71
« Reply #13 on: January 26, 2013, 09:11:08 PM »
I'm extremely curious.. how did it kill itself by missing a tappet cover?
Offline fire113
« Reply #14 on: January 27, 2013, 03:20:06 AM »
Hi ncstatecamp,
Good luck...Georg
...take a look at the picture, it's easy, just use a hammer and a chisel. In my case I did a punch and it was free and I was able to get it out in one piece.
Have a good one...Georg
Offline ncstatecamp
Stuck tappet cover
« Reply #15 on: January 27, 2013, 01:20:37 PM »
Hi ncstatecamp,
Good luck...Georg
Ah ok, that's what I thought but just making sure. thanks
Offline fire113
« Reply #16 on: January 27, 2013, 03:48:23 PM »
Hi ncstatecamp,
Good luck...Georg
...set the chisel from the top, right next from 17mm nut, I did it that way.
Good luck...Georg
« Reply #17 on: January 27, 2013, 05:47:07 PM »
Did you try tapping the tappet cover with a brass or plastic hammer, even a normal hammer and a piece of wood, it can free up the threads and make it easier to get off, heat would do the same thing...
« Reply #18 on: January 27, 2013, 10:07:48 PM »
Get new O-rings for those covers from your dealer. They last about 10 years. Then you just tighten them until they touch metal-to-metal, and back off about 1/8 turn. They wont leak, and will come off easily later on. The size is 30.8mm x 3.1mm, but the 31x3.0 will fit. I have about 100 of them...  :D
Offline ncstatecamp
« Reply #19 on: January 27, 2013, 10:44:50 PM »
HURRA! Finally got it off, what finally did it was using channel locks around the outter round bit rather then the hex bit. Hondaman, Ill take your advice they seem to be a bit squared out and in need of replacement.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #20 on: January 28, 2013, 09:46:19 AM »
I have used the same hammer and cold chisel technique to remove a stuck oil filter cover bolt. The chisel easily bites into the large flared section of the head without damagine the case underneith.
Offline mashfu
« Reply #21 on: February 10, 2016, 11:12:31 PM »
awesome info! chisel made quick work of the tappet covers
Offline Garage_guy_chris
« Reply #22 on: February 10, 2016, 11:28:24 PM »
The other problem i have read about is because the nut portion is so shallow sockets have a hard time grabbing them because of there ramp or cup to aid in getting them on a fastener gets in the way and avoids proper engagement.
My plan to rectify this is to get a 6 point socket and grind or cut the ramps / cup of the socket by shaving the front by 1/4" this way you have the proper size right at the end of the socket and you can get some decent engagement on the hex on the tappet cover
^ I have since made a socket like this and it works great!
Or I know 754 on here makes a tappet wrench
Don't use this to break loose the tough ones, use a socket to get it off, then use this wrench I make to prevent overtightening, and loose fit..
« Reply #23 on: February 11, 2016, 04:24:32 AM »
I used pipe wrench and replaced the chewed up cover with different one.
Offline edwardmorris
  • Youngish
« Reply #24 on: February 11, 2016, 09:43:20 AM »
Frank/754 makes a special wrench for these, makes quick work of stubborn ones.
