Author Topic: South bend Lathe Rebuild  (Read 3722 times)
Offline Flying J
« on: January 27, 2013, 05:54:09 PM »
Picked up a lathe the other day. It was advertised on CL as an Old Laye.  It is a south bend catalog # 33-Y built in 1920. Model #760 making it the 60th lathe built in this model. Dont have any pictures before i started cleaning it but you can imagine what it looks like with almost 100 years of grime. Im going to disassemble clean and reassemble it to get it running. Then i might tear it down again to paint it. I was having a hard time getting on the Machine forum so im just going to post here so i can keep track of my progress.
11  5 20
« Last Edit: January 27, 2013, 06:11:03 PM by ffJMoore »
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: South bend Lathe Rebuild
« Reply #1 on: January 27, 2013, 06:07:29 PM »
Very nice project ffj. Looks like you have everything there? tooling for holding the cutter? Good job saving that thing from some scrapper.
« Reply #2 on: January 27, 2013, 06:10:07 PM »
A shorty like mine..I think mine is 53 or 54ish. Looks like no quick- change, do you have change gears? Think I finally found some for mine. They are made well, but I have a modern 16 incher that I mostly use.
Offline Flying J
« Reply #3 on: January 27, 2013, 06:42:44 PM »
Yes i have the tool post holder and some cutters, a right, left and straight holder. Im not sure what everything is yet. I have never used a lathe. A friend of mine knows a little more then i do about them so i took him with me to look at it. This one is a little old so there are not many parts available but it has power feed and power cross and it also had a full set of change gear that looked brand new. That was the main reason to buy it was because it had the gears. I will eventually sell this one so i can get something to cut metric threads unless i can figure out how to cut metric with the gears i have.
Offline 333
  • Time for change
« Reply #4 on: January 27, 2013, 07:03:29 PM »
Have you heard of OWWM?  Old Wood Working Machines forum is great for shop tools old and new.  They have a metal working area, where you might get some answers and advice from people who own the exact machine.
http://www.owwm.org/
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #5 on: January 27, 2013, 07:32:37 PM »
Practical Machinist has an excellent SB section..
Offline Flying J
« Reply #6 on: January 27, 2013, 07:43:42 PM »
Yeah im trying to get on their site to post but i have not had my membership approved yet. Lots of info on there  though.
« Reply #7 on: January 27, 2013, 09:33:08 PM »
 Let me know if you got dupes of any of the gears, I have not got mine yet and may be missing some, or have dupes. I see you got two dogdrivers.look like small faceplates, may need something like that..
Offline Flying J
« Reply #8 on: January 28, 2013, 12:04:04 AM »
I have a full set of gears with 2x32 gears.
« Reply #9 on: January 29, 2013, 06:49:17 AM »
Very nice!
Offline Flying J
« Reply #10 on: January 29, 2013, 12:44:46 PM »
I think this will be my first prject once i get it running.
http://ixian.ca/gallery/metric/metric.htm
« Reply #11 on: January 29, 2013, 05:09:45 PM »
Nice challenge.
« Reply #12 on: January 29, 2013, 06:24:23 PM »
Just use a frigging Die. I am sure some geek is going to tell me that doing threads on a lathe is easy. bla bla bla. been there. done that. Use a die.
« Reply #13 on: January 29, 2013, 07:56:34 PM »
 Using a die is for girls.. Real men are screw-cutters....
 I cut three different pitches in a couple hours the other day.. But my lathe is like a Cadillac when it comes time to cut a v groove helically along a bar....
 Its usually easier to thread on a lathe, than to play Die-Stock Wrestling..
 Pretty crappy casting, I was  doing.
« Last Edit: January 29, 2013, 07:59:24 PM by 754 »
Offline Flying J
« Reply #14 on: January 29, 2013, 10:23:24 PM »
I want to be able to cut metric for larger things like steering stems or axles that im not going to have a die for.
« Reply #15 on: January 30, 2013, 03:41:42 AM »
Dies get expensive.
« Reply #16 on: January 30, 2013, 07:18:48 AM »
Got it. I thought you were thinking M6.
« Reply #17 on: January 30, 2013, 07:26:44 AM »
The nice thing about a good lathe..any size (within its size) and any pitch (within its range)  On some i can knock off first one in under 10 minutes, next is quicker..
Offline Flying J
« Reply #18 on: January 30, 2013, 09:12:51 PM »
My biggest problem right now is going to be trying to figure out the rats nest ow wiring they have hooked up to the motor. I need to sort it out and see if i can run this motor forwards and reverse.
Offline Flying J
« Reply #19 on: February 05, 2013, 09:02:42 PM »
Figured out the wiring and bought a switch. Now i just have to buy some 5 wiree and hook it all up so i have forward and reverse. Put it all together today and ran it forward. Works pretty good.
Offline cb650
« Reply #20 on: February 05, 2013, 09:10:08 PM »
Very cool!!!    Now for a original steam power and all the overhead drives.   ;D
« Reply #21 on: February 05, 2013, 09:29:29 PM »
LOL! The first machine shop I ever visited had the overhead drives, but they were powered by an electric motor. There were take-off pulleys located near each machine on the common drive shaft, and when they wanted to use a particular machine, they would fit a flat leather belt onto that pulley. The joint where the leather belt was stitched together would make a slapping sound whenever it contacted the drive or machine pulley. Thanks for bringing that memory to the surface! 8)
« Reply #22 on: February 06, 2013, 03:17:54 AM »
Those belts were the main reason to cover your hair in the shop, scary as hell.
