Author Topic: Electrical issue happening to a non-electric kinda guy... (Help!!!)  (Read 7066 times)
Offline 03rangerxlt
Re: Electrical issue happening to a non-electric kinda guy... (Help!!!)
« Reply #25 on: February 13, 2013, 07:22:40 AM »
I'm running a Battery Tender Jr. http://www.amazon.com/gp/aw/d/B000CITK8S/ref=mp_s_a_1?qid=1360768379&sr=8-1&pi=SL75
My new battery is a Yuasa. Damn them things ain't cheap!
1972 Honda CB500 Cafe "The War Eagle"
« Reply #26 on: February 13, 2013, 12:10:28 PM »
If I recall correctly, that one is a 3 stage charger with a true float charge mode.  It should not harm a MC battery with continued connection and operation.  Exception;see below.
I don't recall if it has a reset feature, which would make it return to peak charge mode after some length of time, or battery voltage monitor trip point.  The best battery maintainers have this.
It's a good charger/tender.  But, I don't believe it has temperature compensation to adjust the voltage trip points to those changing conditions.  As chemical activity changes with temps, a full battery when cold will read a lower voltage than a hot battery.  So, chargers often assume the battery being tested/charged at room temperature and deliver voltage based on that norm.  This voltage is too high if the battery is left in near freezing temps, and the battery can be overcharged, and the electrolyte "boiled" away.
So, if your tender is being used with a cold battery, better check the electrolyte levels monthly and replenish with distilled water when it gets low.  Otherwise, your tender can ruin the battery via electrolyte loss, exposing the plates to oxidation.
Offline 03rangerxlt
« Reply #27 on: February 13, 2013, 12:57:54 PM »
Thanks! I should be good then.  At 31F outside, my garage hovers around 57F to 59F.  I was concerned because for the six months I had the other battery, also a gel battery, I kept it on the Battery Tender when it wasnt in use.  But the failer of the battery may actually have resulted from It's price/quality; it only cost $22.  Looks like I got what I paid for!
