Author Topic: Crankcase replacement for a K1  (Read 1371 times)
Offline CB750F2
  • Pat's first Honda 750 F2
« on: July 18, 2006, 04:16:53 AM »
G/Day Everyone. The crankcases of my CB 750 K1 engine are damaged beyond repair. I have a spare set from a K6. Are there any differences that prevent me from using the K6 cases?
Z1 Enterprises advertise a engine seal kit that fits a K1 and K2 but they do not advertise a kit for the K6. Are ther differences in the engine seals for these motors? If the answer is yes what are the differences? Thanks, Pat
Regards
Pat from Australia
Re: Crankcase replacement for a K1
« Reply #1 on: July 18, 2006, 07:46:58 AM »
Cant be 100% sure but a think there may be taranny bearing issues, you will just have to try it and see. The only seal that may be different is again the sprocket seal
Offline CB750F2
« Reply #2 on: July 18, 2006, 02:03:49 PM »
Bryan,Thanks for that. I am in the process of doing just that and I cannot see any differences. I also have a spare set from a K7 and can see from the outside that the output shaft has a larger diameter so the seal will be different and the case itself is wider in that area as if to house a bigger bearing. As far as using K6 cases in a K1 motor I don't think I have a problem.
Someone else may comment. Thanks, Pat
Regards
Pat from Australia
Offline Clyde
« Reply #3 on: July 18, 2006, 06:06:20 PM »
Hi Pat,
On all the crankcases up to and including 1976, you should have no problem
Z1 is a great supplier. Go with ti
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline CB750F2
« Reply #4 on: July 19, 2006, 04:44:40 AM »
Thanks Clyde. I had a good look this arvo and I cannot see anything that would prevent me from doing what I want to do so I am "going for it". Pat
Regards
Pat from Australia
