Author Topic: can someone tell me where these seals go?  (Read 1049 times)
Offline wenger828
« on: February 17, 2013, 02:02:31 PM »
this is the seal kit from dynoman. unfortunately, the powdercoater removed them before prepping the cases and i have no idea where they go. here are two pics, one of the seals and one of the part numbers. can someone save me the guess work and tell me where these seals go?  thanks
« Last Edit: February 17, 2013, 05:21:51 PM by wenger828 »
78' cb750F SS first cafe build! check it out here
http://forums.sohc4.net/index.php?topic=116603.0
Offline DJ_AX
Re: can someone tell me where these seals go?
« Reply #1 on: February 17, 2013, 03:47:02 PM »
Pics aren't working  :o
Offline wenger828
« Reply #2 on: February 17, 2013, 04:12:24 PM »
ughhh hold on a sec.. thought i could copy link location from drop box..
Offline wenger828
« Reply #3 on: February 17, 2013, 05:22:08 PM »
fixed.. pics should appear now
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #4 on: February 17, 2013, 05:35:18 PM »
I asked this same question a month or so ago
http://forums.sohc4.net/index.php?topic=117060.msg1322035#msg1322035
I also just recently rebuilt my engine so i think I might be able to help you out.
(bottom picture from left to right, my best guess here so work with me)
First: Kick starter
Second or third: Gear change
Fourth: I def. know that's the points seal, the metal edge sits next to the crank shaft.
Fifth: 91256-069-651, If that's the smallest, that should be the tack seal on top of the cam cover.
Current ride: 78' Cb750F
Offline wenger828
« Reply #5 on: February 17, 2013, 08:07:09 PM »
thank you very much
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: February 17, 2013, 08:39:51 PM »
couldn't help but notice that out of the 5 seals there are 4 countries of origin- even the Japanese are subbing business...Larry
« Reply #7 on: February 17, 2013, 09:50:07 PM »
Here's a site you will find useful. Plug in your part number bottom right and select your bike.
http://www.motogrid.com/pages/OemParts?aribrand=HOM
Offline Deltarider
« Reply #8 on: February 18, 2013, 06:57:43 AM »
All the Parts List I have offer a list of all the partsnumbers used on that particular model. Just look up the number and you'll find the pages where that part is used. Very convenient.
CB500K2-ED Excel black
Offline wenger828
« Reply #9 on: February 18, 2013, 08:36:21 AM »
thanks for the link Jerry. very helpful
