Author Topic: Check this drilled rotor pattern  (Read 2803 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
« on: February 21, 2013, 09:05:53 AM »
Thinking of buying this disc for my 76 CB550K but is this pattern OK? It looks like the outside holes are pretty close to the edge, is this a problem?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: Check this drilled rotor pattern
« Reply #1 on: February 21, 2013, 09:38:45 AM »
Hey Duane, check these.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/Brake+Rotors+_+Thinned+and+Drilled/HONDA+Front+brake+rotors+CB+450K-500T-500K-550K-550F/
he also has phenolic pads and anti-squeal discs for behind the slave pad if you have a squealer  ;D
« Last Edit: February 21, 2013, 09:47:08 AM by flybox1 »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: February 21, 2013, 11:39:01 AM »
Yes I have a squealer alright.
I wonder about thinning the rotor down by 2mm will it warp easier? Will it effect the run out on the brake piston? 2mm is a lot when taking brake clearances. Just curious.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #3 on: February 21, 2013, 11:52:08 AM »
no, its thinned to 4mm.
pad runout, maybe, but it wouldnt be for at least one season unless youre in the city  :P
Offline Big Bob
« Reply #4 on: February 21, 2013, 12:08:13 PM »
We've been running the drilled & thinned Godfrey rotors on a number of CB750 and CB400F race bikes for the last few years.
We've had zero issues with them after subjecting them to abuse that a street bike will never see.
They're worth every penny and then some.
« Reply #5 on: February 21, 2013, 12:17:38 PM »
Good to hear from another satisfied user, Big Bob.
Not 20 minutes ago I got the email from Godffery that my two 750 rotors are done  ;D   8)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: February 21, 2013, 03:16:44 PM »
Thanks for the info.
Bigbod any brake squeal issues?
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline cameron
« Reply #7 on: February 21, 2013, 03:58:13 PM »
i want.
1976 CB550F
Offline laminaytrap
    • Satchealous Garage
« Reply #8 on: February 22, 2013, 06:36:10 AM »
NBD on the holes, we used to run all kinds of patterns on our race cars, including ones with edge holes (not a great idea from an engineering standpoint, but they worked fine)
Truth is there's a lot of thickness and area in that rotor for the amount of braking you can do with stock design.
Offline Tews19
  • I am no
« Reply #9 on: February 22, 2013, 07:15:53 AM »
I have bought several from godffrey as well. Super light, function great and I have not experienced any warpin yet.
1970 Honda CB750 survivor.
Offline Big Bob
« Reply #10 on: February 25, 2013, 05:15:26 AM »
None whatsoever.  Clean out the caliper and make sure the pads move freely and they're quiet as can be.  I am not of the opinion that the common SOHC front brake squeal has anything to do with the rotors.
This stuff works great:
http://www.international-auto.com/lubricants/wurth-silicone-lubricating-compound-lube-gel.cfm
Offline Big Bob
« Reply #11 on: February 25, 2013, 05:20:18 AM »
Full disclosure:  Jeff is a friend of mine.  Was just out riding with him yesterday.
That said -  if his stuff didn't work I would without hesitation say it didn't work.  He has seen me do stuff like this in person, occasionally with great vigor, at high volume, accompanied with illustrative hand gestures and creative profanity.
« Reply #12 on: February 25, 2013, 05:33:21 PM »
Gifts from Godffery came today  8)
These are the bees knees!
« Last Edit: February 25, 2013, 05:46:27 PM by flybox1 »
Offline brandEn
« Reply #13 on: February 25, 2013, 05:54:29 PM »
Those look great! Does he paint them too?
Re: Check this drilled rotor pattern / Godfferys rotors
« Reply #14 on: February 25, 2013, 06:10:41 PM »
They look blasted, and waxed.
« Last Edit: February 26, 2013, 08:28:28 AM by flybox1 »
