Author Topic: 1974 cb550; Fixin' this baby up!  (Read 32782 times)
Offline Jimsun
Re: 1974 cb550; Fixin' this baby up!
« Reply #100 on: September 04, 2014, 07:28:51 PM »
Those doesnt look like stock sissy bars or are they?
74 cb550
Offline dmonday
« Reply #101 on: September 10, 2014, 01:27:39 PM »
Hey, great build, looks fantastic.
Quick question about setting up the TrailTech gauge. Much to sort out with it? What ignition system are you running? Any other mods that had to be done to accommodate it?
TrailTech gauge was simple to install, very, very easy.  Stock ignition still.  I'll be going to electronic conversion probably over the winter though.
Looking for a cool, one of a kind motorcycle desk piece?
http://advrider.com/forums/showthread.php?t=861422
Offline dmonday
« Reply #102 on: September 10, 2014, 01:29:11 PM »
If you're referring to the bar that the tail light is mounted to you are correct.  It's off of a cb350f.  ;)
Offline Bootsey
« Reply #103 on: September 10, 2014, 04:41:05 PM »
Awesome, cheers for the info. You wouldn't happen to recall which model number of the TrailTech you used? Just that the guys at TrailTech gave me a specific gauge model, and actually said that the tach won't work with points ignition at all....   ???
Offline Bootsey
« Reply #104 on: September 10, 2014, 06:43:33 PM »
Yes, from the few that I've seen, usually there is a wire that either wraps around the plug lead, or attaches to the plug itself.
I wrote to the Tech Support at TrailTech, and he suggested that a points system will not allow the tach to function correctly. My only thoughts were it might be due to the quality or type of  electrical signal picked up by the tach lead, that might differ from points to electronic ignition, but I lack the experience here to really know.
Offline dmonday
« Reply #105 on: September 11, 2014, 07:34:43 AM »
Mine is wrapped around one of the spark plug wires, but I would not say it's accurate.  I'll try the blue wire too when I get the chance.  I'll have to see if I can get you the model number.  I really hate that it doesn't have a trip odometer.  :-\
Offline Bootsey
« Reply #106 on: September 11, 2014, 03:29:46 PM »
Thanks for the info, appreciate it. Don't stress too much about the model number, I think they are all the same apart from the mounting adaptations.
Is the tach slow to respond, or just not particularly accurate?
Is the DIST mode not a trip odometer?
Offline dmonday
« Reply #107 on: September 18, 2014, 07:25:03 AM »
RPM just jumps all over the place.  Pretty much like any digital tach I've ever seen.  I take back the comment about the trip odometer.  I found out it does have one separate from the odometer that keeps track of overall mileage.
Offline spdygnzlz
« Reply #108 on: September 19, 2014, 10:51:57 PM »
I have an Acewell on my bike.  The tach sensor cable is connected to one of the coils and is really jumpy as you say.  I've read somewhere that adding a resistor or something like that (I don't know my way around electronic parts), should calm it down.  It's on my list of things to do for sure...
« Reply #109 on: September 22, 2014, 11:14:30 AM »
I have an Acewell digital tach on my 750.  It's not overly jumpy, but the space increments on the gauge are so small (visually) that I really just go off of sound.  The Dyna 2000 is nice in that it does have a rev limited built in to safeguard the engine from over-revving.
Offline dmonday
« Reply #110 on: October 10, 2014, 07:28:42 AM »
Offline dmonday
« Reply #111 on: June 03, 2015, 12:38:04 PM »
Got my tank and side covers repainted the original color.  Had the black/gold/white painted on instead of decals.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #112 on: June 03, 2015, 01:21:34 PM »
gorgeous looking bike!
Agreed! Great stuff on this thread. Tasteful mods, and I'm considering something similar with my rear fender/tail light area. Maybe purchase one of Ben Oleson's fender eliminators. Back in March when I contacted him, he said he would make more if he was out.
http://www.ebay.com/itm/201265211137?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #113 on: June 03, 2015, 01:55:13 PM »
Very nice!  Tasteful, tasteful bike.  The paint really brought it up a level.
Offline joeyvans
  • Definitely not a
« Reply #114 on: June 03, 2015, 02:54:07 PM »
May I ask.... What length of rear progressives did you go with? Looks like some good height.
1976 CB550 K2
« Reply #115 on: June 03, 2015, 10:03:15 PM »
Did you end up upgrading from points to electronic ignition this last winter?
Offline dmonday
« Reply #116 on: June 04, 2015, 07:28:22 AM »
I did.  It's incredible how much it smoothed out the bike.  I also put in a new clutch/clutch springs.  I was lucky that I bought an extra 550 engine b/c the original clutch basket is apparently the "early" version.  The tangs didn't have the cut outs for the last clutch disk.  I used some parts from the original basket and some from the extra engine to put together one that would work.
Offline dmonday
« Reply #117 on: June 04, 2015, 07:29:09 AM »
I'll have to check.  I can't quite remember.
Offline dmonday
« Reply #118 on: June 04, 2015, 07:31:21 AM »
The day I bought it compared to current.
« Reply #119 on: June 04, 2015, 07:35:12 AM »
I found the same to be true when I swapped out the points and got new coils.
« Reply #120 on: June 04, 2015, 07:36:25 AM »
Look like stock for a 750 - maybe just a little over stock 550 length. Not a bad thing.
Offline dmonday
« Reply #121 on: June 04, 2015, 07:38:31 AM »
Offline dmonday
« Reply #122 on: June 04, 2015, 07:39:20 AM »
I'll have to check.  I can't quite remember.  I'm positive it was the stock length.
« Reply #123 on: June 04, 2015, 07:42:54 AM »
Could be. Once you have it in your mind, you question whether it looks longer.
Offline joeyvans
  • Definitely not a
« Reply #124 on: June 04, 2015, 03:57:38 PM »
Yeah, they seem longer, but I like it! The Hagons I was going to order were a hair longer than stock at 13.2" I believe. Do remember yours, Don?
1976 CB550 K2
