Author Topic: 550K76 front leg numbers  (Read 1195 times)
« on: February 23, 2013, 12:42:47 PM »
My '76 500K2 (Europe) has the same front legs as the '76 CB550K. Left and right - just above the axle holders - you'll find a number stamped. May I ask you '76 CB550K owners to kneel down and communicate what number you have there? What were/are these numbers for and... are the numbers always the same left and right?
The number is small and next to some sort of Japanese sign.
Reason I ask: I have a '4' left and a '5' right.
« Last Edit: February 23, 2013, 12:52:42 PM by Deltarider »
Online Stev-o
Re: 550K76 front leg numbers
« Reply #1 on: February 23, 2013, 06:41:17 PM »
Mine are 2 & 4 on my '76K.
« Reply #2 on: February 23, 2013, 11:33:24 PM »
Thanks. So I am not the only one who has different numbers left and right. Still curious what they are there for.
« Reply #3 on: February 25, 2013, 12:25:09 AM »
How about the other 500s and 550s?
« Reply #4 on: February 25, 2013, 12:47:40 AM »
ill look later for you.
Offline Lars
« Reply #5 on: February 25, 2013, 02:30:06 AM »
Will check mine later, too.
...if you got the ability to act...
« Reply #6 on: March 02, 2013, 11:28:31 PM »
my left has 4 raised cast,the right has 6 raised cast and a hand punched 7 k,they both have h f raised cast in the same area,this is a 73 500.
« Reply #7 on: March 02, 2013, 11:56:45 PM »
Thanks
Online Stev-o
« Reply #8 on: March 03, 2013, 06:32:37 AM »
Could they just be cast numbers?
« Reply #9 on: March 03, 2013, 07:39:17 AM »
Wat is a cast number for?
« Reply #10 on: March 03, 2013, 11:29:30 AM »
probably if they have a faulty leg they know what die it came from and can stop it being used untill its looked at?
Offline percolate
« Reply #11 on: March 03, 2013, 12:08:57 PM »
Related question:
I have a 76 550f and a 77 550k parts bike. Want to rebuild forks - or rather rebuild the 77 fork tubes and put them on the 76. 76 has the boots, 77 does not. I like the boots. I can put the boots on the 77 fork tubes, right?
And the 77 has a 7 on the left, nothing on the right.
The solution is painfully obvious once you know exactly what the problem is.
1976 CB550F - http://forums.sohc4.net/index.php?topic=118564.0
