Author Topic: What size would a .30 over cb750 be?  (Read 2065 times)
Offline 75 super sport
« on: March 27, 2013, 09:18:53 AM »
Had a guy offer to put a big bore kit into my 1975 cb750. He said it would be .30 over. what size would that make it?
"Smoke em if ya got em"
Offline lucky
Re: What size would a .30 over cb750 be?
« Reply #1 on: March 27, 2013, 09:46:16 AM »
For the 736cc engine, @8.6:1 compression with .030 over is 754.523cc
Bore X stroke+.030 X ratio = cu. centimeters x4=
« Reply #2 on: March 27, 2013, 10:02:23 AM »
I've never seen it done like that before. what does the CR ratio have to do with CC's?
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #3 on: March 27, 2013, 10:05:39 AM »
Let's try again.
(Cylinder Diameter divided by 2) x (Cylinder Diameter divided by 2) x pi x stroke x 4 cylinders = displacement.  Has nothing to do with compression ratio.
Original Bore and Stroke is 61 x 63 mm, or 6.1 x 6.3 centimeters.
0.030" is 0.762 millimeters, or 0.0762 centimeters.
New bore is 6.1762 centimeters.
New displacement is then ~ 755 cubic centimeters.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline lucky
« Reply #4 on: March 27, 2013, 01:26:30 PM »
Let's try again.
Did you round that final number off?
Offline lucky
« Reply #5 on: March 27, 2013, 01:31:31 PM »
The compression ratio is important because the cc's is the measure of how much space is in the combustion chamber. With different piston shapes the amount could be different.
For example valve reliefs cut into the piston top  would have more volume .
A flat top piston would have less.
But why quibble over 1/2 cc total on the 4 cylinders?
Offline lucky
« Reply #6 on: March 27, 2013, 01:54:31 PM »
Let's try again.
"Let's try again."
So condescending.
Offline HonderCB
« Reply #7 on: March 27, 2013, 02:18:55 PM »
Let's try again.
"Let's try again."
So condescending.
particularly ammusing since he came up with the same number as you, lucky.   ;D
77' CB750F
81' CB650C - SOLD
« Reply #8 on: March 27, 2013, 02:30:16 PM »
Sorry - didn't mean to sound "mean".
However, displacement has nothing to do with compression ratio.  Swept volume is swept volume.  Domes, piston reliefs are not related to displacement.  Never has been, never will.
As yes, I did round the answer.  I recall the answer was about 754.975xxxx - anyway, it was very close to 755.  Extreme precision didn't seem necessary, or appropriate.
