cool forum here guys, yes I'm new but been around engines my entire life and thought I would weigh in on this. sorry its long.
there is lots of myths regarding fuel I work in the auto industry for a major Japanese MFG and raced cars for a number of years so I spent a lot of time on a dyno as we were fuel restricted... technically there was no legal fuel for our class, we couldn't run race fuel but we were not allowed oxygenated fuel which was all pump gas available in California.
If an engine was designed for regular fuel you will not gain power with premium assuming your running as designed. I have tested this on a dyno over and over
if it feels more powerful your probably suffering from "clean car runs better syndrome" very common even I have had it..
deposits will not increase with premium, byproducts of combustion are the same regardless of octane any unburnt fuel will leave via the tail pipe hence higher emissions on older less optimized engines
Here in Ca we only can get E10 with a push toward E15. 10%/15% ethanol BTW the EPA is currently pushing through this requirement for all states, this is very political too.
Ethanol is bad for us older bike owners for a number of reasons, its corrosive, it attacks rubber, it has poor knock resistance, it has less heat energy per unit, it phase separates if left for more than a month(breaks down into its separate constituents and no run) it plugs pilot jets with a vengeance, the good is that it reduces emissions by a small percentage but on a modern car you will see a decrease in fuel economy but I don't think it cancels out the gain.
the AMA is fighting to prevent higher ethanol content only fuels due to the MC industry
the reason your car will get lower MPG with ethanol blends is that it adjusts the mixture as needed on the fly, your bike with fixed jets will just keep putting the same amount of fuel in no matter whats happening in the combustion chamber within reason.
as a side note you can get really high octane fuel at the gas station out of the diesel pump but I would not recommend that.
here's my take
I run premium all the time no matter what my engine was designed for and here's why, it does give a level of knock protection and our older engines can go out of tune and put us into the danger zone quickly, vacuum leaks, points wearing, older crappy parts, the list goes on.... I also ride mostly 2 strokes the extra 75 cents a tankfull isn't going to kill me.
I'm sure there will be some disagreement with what I have said, if you look around the internet theres lots of information regarding fuel from SAE and other scientific sources.
Cheers
