This looks like it will be pretty simple to wire up, but I could use some positive reinforcment, to ease my mind.
In fact, whoever designed this thing might have had a Honda! Many of the wires match color for color to the Honda wiring diagram.
I have a few questions, but I'll take them one or two at a time so as not to get everyone confused.
Here's all the instructions that came with the Danmoto, if you can really call them that. Notice my handwriting on the second pic. That's the easy, idiot-proof stuff!
I'll be using the wires that once went to the "idiot lights" on the dash of my CB500. Those should match up to the turn indicators, oil pressure, neutral, and high beam on the Danmoto.
The turn signal bulb on the stock dash has two wires...orange and light blue.
LB comes from the RH turn signal,
O comes from the left. Pretty straight forward to match those up, right?
Next, the oil pressure switch has a blue/red wire on the stock harness. The dash light has the blue/red and a black wire. The black just runs power to the bulb, right? If the Danmoto has a 12V source, all I need is to run the
B/R wire from the oil pressure switch to the
BL/W wire on the Danmoto, correct?
Same idea with neutral lamp. It has a light green/red wire from the neutral switch and a black wire to power the lamp. I can take the
LG/R wire that once went to the dash lamp and plug it into the
LG/R on the Danmoto.
