Author Topic: 1972 CB350F LED Light Issue  (Read 818 times)
Offline hondabbqman
« on: April 07, 2013, 01:10:05 PM »
OK, finally got around to installing the LEDs I bought from superbrightleds a while back.  Put a 1157-RLX3 in the taillight - works fine.  Put appropriate color BA9s-G4 in handlebar panel.  All of them looked great - for a little while.  The Amber turn signal works great, the blue high beam works great.  Both the Neutral green and oil light red went dead.  I put the original bulbs back in and they work fine.  Should I have gone with something else or what?  I tried the bulbs in the other spots and they were dead.
Any thoughts?
Thanks in advance.
1972 Honda CB350f
1975 Honda CB550
1971 Honda CB750K1
1975 Yamaha RD250
Offline kghost
Re: 1972 CB350F LED Light Issue
« Reply #1 on: April 07, 2013, 02:31:26 PM »
Which G4's were they? Probably one R4 and one G4 yes?
The led's run at about 2-3 volts and have resistors built in for different voltage. E.I. 6,12,24 volts.
If you have a 6 volt bulb in a 12 v installation it's probably burned them out.
« Last Edit: April 07, 2013, 02:33:13 PM by kghost »
Stranger in a strange land
Offline hondabbqman
« Reply #2 on: April 07, 2013, 02:59:31 PM »
They are 12 volt bulbs unless mis-marked somehow.  I double checked and they are 12 volt.  Maybe they were mismarked?
1972 Honda CB350f
1975 Honda CB550
1971 Honda CB750K1
1975 Yamaha RD250
Offline kghost
« Reply #3 on: April 07, 2013, 06:00:07 PM »
It's possible.
Unless they have the correct resistor ballast they are toast.
Since the regular bulbs work.... Doesn't sound like wiring issues.
