Author Topic: New Here..just purchased a 77 f2..questions  (Read 1441 times)
Offline MOONDOGNYC
  • BLOOD, SWEAT AND GEARS
« on: April 28, 2013, 03:14:34 PM »
 Hello all. I have just purchased a 77 CB750 Supersport. I am currently in the teardown process, and have a few questions.
 Does anyone have a diagram/pics of the vents and where they go ? I see the top half of some type of breather canister, attached to the bottom of the battery box, but I am wondering if I can just vent to a filter and remove the breather canister ? I have three vents with no hoses. 1)oil tank  2)top of motor 3) bottom of motor
 Any advice on a good 4-1 ? and one last question, is there any way to do the gauge faces rather than replace them?
  Thanks, Moondog
1977 CB750F
Re: New Here..just purchased a 77 f2..questions
« Reply #1 on: April 28, 2013, 04:22:35 PM »
Welcome. MotoGP Werks makes the best exhaust for the CB750.
Call Chris....
http://www.motogpwerks.com/custom-projects.html
Offline RSchaefer
« Reply #2 on: April 28, 2013, 06:16:17 PM »
Welcome!  Gauge faces are rebuildable, I did mine.  I live in the southwest and my stock gauges were burned up by the sun (faded).  I purchased a pair of rusted out gauges from a guy in boston, but the actual face was pristine and swapped.  Also set the odometer back to zero.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
bollingball
« Reply #3 on: April 29, 2013, 07:40:09 AM »
  Thanks, Moondog
Sure you can but you should not it is called a breather separator it has 3 hoses 2 at the top 1 at the bottom the bottom is a drain that should have a plug on it and you drain the junk out once in a while the 2 at the top 1 goes to the valve cover and the other top one goes to the air filter box. The diagram is in the Honda service manual section 1-11 I think the one from the oil tank goes to the bottom of the motor but not sure so check on this one.
Ken
Offline MOONDOGNYC
« Reply #4 on: April 29, 2013, 04:02:19 PM »
Thanks Ken.. I am stumped on where these hoses go. I just bought a separator on ebay and all I need now is some help on where the hoses go. Thanks.
Anyone have a pic/diagram ?    thanks.
1977 CB750F
bollingball
« Reply #5 on: April 29, 2013, 04:07:57 PM »
If you download the manual from this site it shows the routing on 1-11. I will see if I can scan it from my copy I just changed over to windows 8 am not to good with it yet. However you really need to download if for future use it is really good to have.
Ken
« Last Edit: April 29, 2013, 04:10:13 PM by bollingball »
bollingball
« Reply #6 on: April 29, 2013, 04:34:37 PM »
see if this works. If you click on it you may see it better sorry.
Ken
« Last Edit: April 29, 2013, 04:36:10 PM by bollingball »
Offline MOONDOGNYC
« Reply #7 on: April 29, 2013, 05:01:33 PM »
Perfect !  Thanks Ken
1977 CB750F
bollingball
« Reply #8 on: April 29, 2013, 06:09:18 PM »
At first I took mine off then after talking with TT I put it back on it keeps a vac. or negative pressure on the bottom end and if you look how things flow it goes through the filter box but not the filter itself.
Ken
Offline Stoli
« Reply #9 on: April 30, 2013, 03:22:59 PM »
I don't think anyone addressed this one yet -
The tube coming out of the oil tank (which is an overflow) gets connected directly to the tube coming out of the bottom rear of your case.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
