Author Topic: Bleed screws and caliper bracket  (Read 1018 times)
Offline crp_iii
« on: July 31, 2006, 09:16:50 PM »
Any body know what size the bleed scres are for the brakes on a '77 CB 750 F?  I tried to bleed them tonight and sheered off two of three. >:(   The third will only turn about 1 time around before it sticks so I know it is going to snap. Lots of liquid wrench didn't seem to help.
I am waiting for the Clymers and Hayes manuals I ordered to arrive.  Should there be a spacer on the rear wheel between the bracker for the brake and the wheel?  I am wondering if my caliper bracket is bent of just missing a piece.  It is rubbing on the disk.  There is no other damage I can see on the right side other than the tail light doesn't match the other 3.
72 CB350F With poor man drag pipes
77 CB750F
Re: Bleed screws and caliper bracket
« Reply #1 on: July 31, 2006, 10:17:08 PM »
Don't know about the bleed screw size(s). My 75 750F uses different sizes front and rear. If you haven't already you should consider Speed Bleeders. They are sweeeeet !
