Author Topic: I sure know how to screw things up!  (Read 2131 times)
Offline 223D
« on: June 16, 2013, 09:42:29 PM »
In the process of rebuilding my carbs, I managed to break the piece pictured below.  :'( Can this be replaced on its own, or would it require me purchasing a whole throttle plate assembly?
Thanks,
Matt
« Last Edit: June 16, 2013, 09:44:48 PM by 223D »
Offline phil71
Re: I sure know how to screw things up!
« Reply #1 on: June 16, 2013, 09:55:21 PM »
If it were me, I'd get a really fine drill bit, and make a hole through the part, and the arm . Then, i'd take a somewhat bigger drill bit, and make a 'sink', or shallow hole in the ball , to act as countersink. Then find a long, thin sheet metal screw and thread it in.the spring tension is on the shaft, so it shouldn't need a ton of strength to get the job done.
Offline 223D
« Reply #2 on: June 18, 2013, 12:23:05 PM »
Thanks Phil. That's probably going to be my best option. I considered having it welded, but I don't know if that would work.
« Reply #3 on: June 18, 2013, 12:45:47 PM »
find a new mechanism,thatll be hard and fiddly to drill and a screw wont last long.
bollingball
« Reply #4 on: June 18, 2013, 01:05:28 PM »
Yep I agree with Dave for a more long term fix get another part check with
http://forums.sohc4.net/index.php?action=profile;u=16522
Ken
Offline mono
  • Definitely no
« Reply #5 on: June 18, 2013, 01:23:16 PM »
honestly if it were me i'd get it welded.  the caps that fit on those balls aren't that big, so there's room for a moderately sloppy weld.  also will be far cheaper and/or easier than finding just that piece (unless someone here has one laying around).
Offline phil71
« Reply #6 on: June 18, 2013, 04:37:58 PM »
If you have a small vise, you can drill it. Seeing as how you have nothing to lose at this point, I think you could drill BOTH the intact one, and the broken one, and just pin the whole deal like a broken bone.
« Reply #7 on: June 18, 2013, 04:51:45 PM »
I rather prefer this route, if you can't find another used one.
Isn't that arm aluminum and the part steel, stainless I think.  You aren't going to weld that in place, due to the different melting temps.
Yeah, it can be fixed, but replacement is a better option, imo.
Put up a want ad.
Offline 223D
« Reply #8 on: June 18, 2013, 06:40:49 PM »
Thanks for the advice gentlemen, I sent a message to harisuluv. Hopefully he has a replacement. I would feel much better with a new one.
Offline harisuluv
« Reply #9 on: June 18, 2013, 06:49:32 PM »
Yup I got one clean and ready to rock.
Offline 223D
« Reply #10 on: June 18, 2013, 07:47:15 PM »
Thanks to harisuluv, a new piece is on the way! Thanks for the help, hopefully she'll be on the road soon!
Offline mono
  • Definitely no
« Reply #11 on: June 19, 2013, 05:21:39 AM »
well, that's an amazingly good point.  i thought the whole thing was aluminum.  glad you found a replacement! :)
