Author Topic: Mounting Tires CB500 - Michigan  (Read 582 times)
Offline joemcvw1951
« on: June 25, 2013, 11:33:41 AM »
Getting some new tires from American Motorcycle Tire - Continentals
I called around and I'm hearing nobody wants to mount them (unless bought there) - that was news to me.
I changed tires in the 70's and it wasn't a huge deal - are todays' tires any different ?  Should I be able to mount them myself ?
Thanks
Re: Mounting Tires CB500 - Michigan
« Reply #1 on: June 25, 2013, 12:01:17 PM »
Usually getting the old ones off is harder than putting the new ones on.I do all mine,but with a good set of tire irons,makes the job so much better.Maybe an small independent shop out there can help you out or run a little add on CL for that job.Used to be a couple of tire slingers around here that did it pretty cheap.
Offline Rodger
« Reply #2 on: June 25, 2013, 03:31:24 PM »
There is a guy in St Clair Shores, he mount tire and balances them for $20 a tire.  Has Snap-on tire machine and balancer at his house, cant find is number at the moment.   Check Craigs list here a guy in Garden City
http://detroit.craigslist.org/wyn/mcy/3887410127.html
69 Honda CB350, 71 Honda CB350K, 72 Honda CB350K Café,
75 Honda CB400F Blue, 75 Honda CB400F Red 73 Honda CL175 and 76 Honda CJ360
Offline acollin
« Reply #3 on: June 25, 2013, 03:51:49 PM »
1 old sofa cushion
1 rubber dead blow hammer
1 bucket soapy water.
They really are tougher to remove-- if the old tires are truly spent--deflate, pull out the inner tube and with great care cut them off the rims.
« Reply #4 on: June 25, 2013, 04:05:39 PM »
If you do take them somewhere do not be surprised to see some rust inside the rim.The tire slinger won't really care but I like to clean that off when the tire is off and address it. Don't like the idea of that crusty cancer chaffing on my tube.
Offline 72 yellow
« Reply #5 on: June 25, 2013, 04:36:31 PM »
Detroit Wheelz is the place in St. Clair Shores.  His name is Rich.  586-420-3689.  Had several tires mounted there.  Nice guy to deal with.
Offline joemcvw1951
« Reply #6 on: June 25, 2013, 06:04:28 PM »
thanks for the help guys
