Author Topic: White plugs  (Read 1757 times)
Offline nevernoluck
  • Nope I don't have a clue
White plugs
« on: July 09, 2013, 06:34:32 PM »
Sorry no pics right now but I have an 80 650, all but the carb sync of the 3000 mile tuneup done, stock 4-4 exhaust, 90 mains and 35 slow jets, stock air filter no vacuum leaks, running lean with white plugs right? Do I sync carbs then check again or jet it first? What jets next? Ideas? Plugs are a champion something in the 12 number range, tomorrow morning I'll pull them and take pics
« Last Edit: July 09, 2013, 06:44:22 PM by nevernoluck »
Offline Vincent P
Re: White plugs
« Reply #1 on: July 09, 2013, 06:45:28 PM »
Easier to synch and adjust the air fuel mixtures first then test; if the issue persists, then I would go with the jetting and a repeat of the synch and idle.
1973 Honda CB750 K3
Offline nevernoluck
Re: White plugs
« Reply #2 on: July 09, 2013, 06:52:47 PM »
Oh and the pilot screws I believe are 1 1/2 turns out, I know it only affects idle just trying to give all the info I can.
I was thinking of syncing first too, other than that there is no adjustments besides changing jets or pilot position on these carbs
Offline Vincent P
Re: White plugs
« Reply #3 on: July 09, 2013, 07:24:25 PM »
Unless you have been messing around with the jetting originally, then I think its just a matter of synchronization to get some of the leanness out of them and get a bit more fuel going in.
1973 Honda CB750 K3
Offline nevernoluck
Re: White plugs
« Reply #4 on: July 09, 2013, 07:31:12 PM »
I haven't done any rejetting and I believe these are the stock jet sizes, I was hoping to hear that
Offline cheftuskey121
  • Super Newbie
Re: White plugs
« Reply #5 on: July 09, 2013, 07:48:49 PM »
pretty much posted with the same concerns just now! funny how that works! hope you get it resolved
Offline scunny
  • don't call me expert
Re: White plugs
« Reply #6 on: July 10, 2013, 01:28:38 AM »
don't think a carb sync will do anything for a lean running motor.
first cab off the rank put some NGK8ea or their equilivent and then see whats happening. your main jet sounds about right but I haven't access to my manuals at the mo.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Vincent P
Re: White plugs
« Reply #7 on: July 10, 2013, 10:33:08 AM »
Use these exact plugs and they are the best.
1973 Honda CB750 K3
Offline InTheStreet
  • Ha, you let me be a
  • When in doubt, flounder about.
Re: White plugs
« Reply #8 on: July 10, 2013, 01:24:22 PM »
What makes you think that your lean problem isn't only on the idle circuit?  Are you doing plug chops at various RPM or are you riding, pulling up at or near an idle and shutting it off?  If the latter, you could just be reading your idle mixture, in which case you just need to richen up your idle screws.
You should get the NGK's.
1975 CB550K1
1980 CB650C (parting out)
1980 GL1100 (sold and missed)
Offline curemode2002
Re: White plugs
« Reply #9 on: July 10, 2013, 02:54:51 PM »
+1 on the NGK's these bikes don't take kindly to american plugs  :o (trust me on this one). With my 650 she always runs lean at idle even warm they are supposed to that's why the air adjust screws are capped  >:( (dang EPA thing). You can actually adjust needle hieght in these carbs with small washers but I would change plugs, sync and set the air screws before you get to crazy. Jets for this model can be easily had at Z1 Enterprises or Siriusconinc for pretty decent prices and you can usually get a couple sets for tinkering.
Bikes:
1980 CB650 Sold
2015 Monster 821 Stripe
Offline nevernoluck
Re: White plugs
« Reply #10 on: July 10, 2013, 03:20:38 PM »
I will put the ngk in tomorrow and do some testing, they are sitting in the closet might as well use them, got the carb sync done and seems to cruise better but had the girlfriend on the back so was taking it easy, might have the cruising surge about taken care of
Re: White plugs
« Reply #11 on: July 10, 2013, 03:39:07 PM »
I've noticed the accelerator pump system on the CB650's are REAL easy to get clogged up & if they aren't All squirting nice & evenly in each carb. it'll give you a lean running condition.The tank gets "rust dust" in it and the accel. pump spigots in ea. carb. throat seem to be the first thing to clog up...along w/ the accel. diaphram having it's own issues.
They are a pain to clean out(it requires removing the rack of carbs),but once they're clean it'll run Great ;) !
Offline nevernoluck
Re: White plugs
« Reply #12 on: July 10, 2013, 05:22:12 PM »
Not so white?
Offline Vincent P
Re: White plugs
« Reply #13 on: July 10, 2013, 07:20:43 PM »
Looks like normal wear to me. I wouldn't worry.
1973 Honda CB750 K3
Re: White plugs
« Reply #14 on: July 11, 2013, 07:43:48 AM »
+1 I don't see the white chalky looking buildup I saw when mine was lean. Those plugs look just right. ;D
Bikes:
1980 CB650 Sold
