Author Topic: Oil cooler 3/8 line,is that ok???? 72cb750 chopper  (Read 836 times)
Offline mario medeiros
« on: July 15, 2013, 04:56:55 AM »
The oil tank i have has a 1/2 fitting (not able to replace,chopper tank) and the oil cooler i installed uses a 3/8 line.Will going from 1/2 to 3/8 line harm the bike?or will it still have lots of oil flow?Thanks
Offline bjbuchanan
Re: Oil cooler 3/8 line,is that ok???? 72cb750 chopper
« Reply #1 on: July 15, 2013, 05:46:12 AM »
It is fine it won't pose a massive restriction. Flow area is a bit smaller tho
Offline SOHC Digger
  • I'm not an
« Reply #2 on: July 15, 2013, 06:41:54 AM »
How about posting some pics of this bike?  You've been here long enough... now it's time for show and tell.
« Reply #3 on: July 15, 2013, 12:09:29 PM »
Will get pics this week,so i am thinking that going to 3/8 is ok???if the lines going into the cooler are 3/8 then the inside is also that.Should i just remove the barb fitting at the motor and replace with a 3/8 or leave the 1/2 fitting and run 1/2 hose going to the cooler then going to the oil tank?
Offline SOHC Digger
  • I'm not an
« Reply #4 on: July 15, 2013, 01:31:10 PM »
Leave it.  No sense reducing anything else.
Offline jamesb
« Reply #5 on: July 15, 2013, 02:42:04 PM »
I have 3/8 on my chopper and haven't had any problems at all. They have been on there for 4 yrs now.
Offline lucky
« Reply #6 on: July 15, 2013, 05:43:53 PM »
The CB750 chopper website guys say the 3/8 works ok.
Ken at Cycle -X likes the 1/2 inch . But measure the stock ID and then measure the Inside of the 3/8 and see just how close they are.
Online scottly
« Reply #7 on: July 15, 2013, 07:28:52 PM »
The lines to the oil tank are large, due to the lack of pressure. The oil supply line feeding the oil pump actually is a suction hose, and the restriction of the oil cooler and smaller line *may* possibly cause oil starvation at higher RPMs. Oil coolers are normally plumbed in to the high pressure side of the system, at the filter boss.
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #8 on: July 15, 2013, 07:45:54 PM »
Havn't been here long, but I do have a lot of past experience with flow of fluids. I wouldn't do it. stick with 1/2" if you can. Starvation on a high RPM motor is not what I would like to experience.
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
