Author Topic: 72' CB750 CARB QUESTION  (Read 1406 times)
Offline zekd
  • the "b" team
« on: July 17, 2013, 08:57:34 AM »
Hey guys so when I went to rebuild my carbs I accidentally broke of one of the arms that hold the float in place so I went searching for a new replacement carb. I finnaly found a guy who was advertising the right one. But it turns out after closer look the one i bought has a different layout. It channel that goes to the main jets are swapped. the carb of the left is the stock carb that I broke. Will this be a problem or not?
Black 750K8
Re: 72' CB750 CARB QUESTION
« Reply #1 on: July 17, 2013, 09:12:05 AM »
Don't know if it will or will not. But if you still have the post there is a guy here that can put it back like new. Look in services offered micro welding. Found it.
http://forums.sohc4.net/index.php?topic=118804.0
Offline zekd
  • the "b" team
« Reply #2 on: July 17, 2013, 09:18:29 AM »
Looks like ill be digging through my whole work space! thanks!
Offline bjbuchanan
« Reply #3 on: July 17, 2013, 12:53:30 PM »
He wasn't advertising right, if it is all flipped it is for the other side of the bike you broke the float post from. It won't have the drilled passage for the fuel tee where it needs it
Offline cheftuskey121
  • Super Newbie
« Reply #4 on: July 17, 2013, 01:32:10 PM »
this is correct. there are two of each facing different ways. because of the carb tees, you have to have the correct orientated carb body otherwise you can use it.....easily. I am sure there is a way around it but ideally your carbs should be as plug and play as possible.
