I've got (what seems to be) clean jets now (air passes through them). I'm reassembling using the gasket kit from Honda. Only problem is I have an extra O-ring I can't figure out. I've got the ones on the air jet, the bowl gasket, the top gasket, the one on the bowl drain, around the tubes running between the carbs, and I've got an extra gasket... in each package. And there's a bag marked "A" and I can't figure out what on earth the O-ring in it is.
Additionally I am missing two of the washers for the needles. Any thoughts on where I might find them? I've look at the local tool stores, no dice.
