So I ran across this unopened can of motorcycle Gumout Carb Cleaner for 2 and 4 cycle motors at a flea market. Says 4 oz. per gallon and contains xlyenes. I was going to display the can in the shop. Just how old is this stuff? Would YOU use it in your bikes or do you think age would be a problem?
_________________________________________________________________
Someone else mentioned methylene chloride..which is what most carb cleaners had back in the day.  This would also apply to Xylene and Benzene BTW. We used to have it in tanks..just soak carbs..fuel pumps..generators..electric motors..etc..in it.  Methylene chloride won't destroy rubber or plastic..but if left to sit in it..they will soften and deteriorate (like over night..24 to 48 hours).  But brief soaks of an hour or two won't hurt anything.  When carbs..et al were really dirty..we had to disassemble take any rubber or plastic parts out..to clean the rest of metal..etc..  It takes off paint..if left to soak!
Anyway..most of this is moot..because with rare exception..you can't get them over the counter anymore.  They're known carcinogens..with repeated exposure.  Also well known to cause liver and brain damage if inhaled or allowed to soak through the skin repeatedly.  One of the main reasons they were withdrawn from market..is due to high incidence of liver and brain damage in workers exposed over time.  Like so much of the old stuff we used to use..get great results from..methylene chloride..et al. (as with leaded gas and paint..certainly with cyanide..PCB's) have been found to be just too hazardous for common use. Certainly nasty stuff from a health point of view.
Would suggest just looking at can for nostalgic reasons.  But if decide to empty contents..you should take to hazardous waste facility..as it's not good at all to dump down drain..or in sewer systems.
Sorry if this sounds like wet blanket..but from years of background as health professional..that's my opinion on this..
Ichi
