Author Topic: Vintage Carb Cleaner????  (Read 4224 times)
Offline Johnie
« on: July 26, 2013, 11:32:44 AM »
So I ran across this unopened can of motorcycle Gumout Carb Cleaner for 2 and 4 cycle motors at a flea market. Says 4 oz. per gallon and contains xlyenes. I was going to display the can in the shop. Just how old is this stuff? Would YOU use it in your bikes or do you think age would be a problem?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MoMo
  • Ride like you're invisible
Re: Vintage Carb Cleaner????
« Reply #1 on: July 26, 2013, 01:02:02 PM »
The design style of the can looks so  70s, for display purpose only ;)...Larry
Offline Johnie
« Reply #2 on: July 26, 2013, 01:19:55 PM »
Yah, it reminds me of the old HEET cans of gas line de-icer. I will toss the fluid and display only. Do not think I would want to try it in the 750's.
Oshkosh, WI  USA
Online seanbarney41
« Reply #3 on: July 26, 2013, 01:28:50 PM »
I read the title and thought this was gonna be about my six year old gallon bucket of carb dip.  I have probably used it to rebuild 10-15 sets of carbs.  The level has dropped or evaporated so much that I have to soak one side then turn 'em over to submerge carb bodies...but, I think this stuff grows more powerful with age!     ...so much so I am starting to think it is gonna eat it's way out of the can!
Offline goofy3392
« Reply #4 on: July 26, 2013, 01:42:44 PM »
Do you filter your old carb cleaner? I have a couple gallons in my garage, only cleaned a couple sets in each and they're pretty dark from the dirt that comes off the carbs and what not. Was thinking about filtering it through a coffee filter but haven't got to it yet.
Sent from my ADR6410LVW using Tapatalk 2
1976 CB550
Online seanbarney41
« Reply #5 on: July 26, 2013, 05:15:31 PM »
nope, mines a very dark shade of brown...after it instantly liquifies any varnish and gunk, you have to be sure and rinse it off with a spray can.
« Reply #6 on: July 26, 2013, 06:18:34 PM »
It will eat through the can. Be careful, it smells awful when it runs all over the floor.
Offline Johnie
« Reply #7 on: July 26, 2013, 06:25:22 PM »
I did have a can of Gunk carb cleaner start to leak. I went out and got another paint can for it. When I dumped it out the bottom was full of the stuff that came out of many carbs. So my other cans I slowly dumped them out and got all the crap out of the bottom of the cans and put the cleaner back in for another day. No sense in lowering the basket into a bunch of old carb dirt.
Oshkosh, WI  USA
« Reply #8 on: July 26, 2013, 06:44:42 PM »
What you have in your hand is real carb cleaner. It is probably fine to use. That has all the good stuff the new stuff can't have anymore.
Offline Johnie
« Reply #9 on: July 26, 2013, 07:17:21 PM »
I think what scares me Bobby is the new stuff is like 1 oz per gallon and this stuff says 4 oz per gallon. I would hate to ruin my carb rubber or plastic parts. Of course now that I think if it there is not really any rubber or plastic in the 750's I have that I can recall anyway...
Oshkosh, WI  USA
« Reply #10 on: July 26, 2013, 07:31:45 PM »
Let's look at it this way. Your bike and the cleaner were probably made about the same time. If it was fine then, what changed?
« Reply #11 on: July 26, 2013, 07:43:33 PM »
I would use it in a heartbeat.  But, like all carb cleaners keep it away from rubber that you want to reuse.  Carb cleaner use to work really well, until the EPA removed all the good stuff.
The best carb cleaner had methylene chloride in it.  Yes, it will strip paint, too.  Doesn't hurt metal bits at all.
« Reply #12 on: July 26, 2013, 08:02:12 PM »
Re #8-11 posts..
 I believe 750 carbs have a plastic locator in the side of the bodies that fits in a groove in the slides.
 Be VERY CAREFUL  with these, some cleaners Did eat them..
 To be safe ..see what others on here are using ..that works..
« Reply #13 on: July 26, 2013, 08:37:50 PM »
TT is right. if you ever used carb cleaner back in the day, it did the job and harmed nothing. It actually cleaned.
« Reply #14 on: July 27, 2013, 04:33:52 AM »
The style of that moto bike does look 70's.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #15 on: July 27, 2013, 05:16:02 AM »
I don't believe it's a carb dip. 4 oz. per gallon into the tank as a fuel additive. Cleans-as-you-drive type of thing similar to Berryman's, Techron, etc. It'll probably work great and not hurt anything, though definitely not OSHA approved these days.  ;D
MCN DTF
« Reply #16 on: July 27, 2013, 08:00:24 AM »
Right you are Stu, it was an additive and I am sure not politically correct. Like the Gumout spray back in the day. You could take a gum caked carb and start spraying and watch the crap flow right off down to clean metal.
« Reply #17 on: July 27, 2013, 08:05:21 AM »
Anybody else ever throw a half full can of that good ole' stuff in a burning burn barrel when you were a kid  :o  8)  Spray paint works well also    ;)
« Reply #18 on: July 27, 2013, 08:17:58 AM »
Full ones..
Offline Johnie
« Reply #19 on: July 27, 2013, 10:57:26 AM »
754...I thought those were metal locators in the slides? At least that is what I thought I saw on my KO. I will have to check that out. Wouldn't plastic slide locators wear out fast?
Oshkosh, WI  USA
Offline Ichiban 4
  • "Ichi"
« Reply #20 on: July 27, 2013, 07:42:05 PM »
_________________________________________________________________
Someone else mentioned methylene chloride..which is what most carb cleaners had back in the day.  This would also apply to Xylene and Benzene BTW. We used to have it in tanks..just soak carbs..fuel pumps..generators..electric motors..etc..in it.  Methylene chloride won't destroy rubber or plastic..but if left to sit in it..they will soften and deteriorate (like over night..24 to 48 hours).  But brief soaks of an hour or two won't hurt anything.  When carbs..et al were really dirty..we had to disassemble take any rubber or plastic parts out..to clean the rest of metal..etc..  It takes off paint..if left to soak!
Anyway..most of this is moot..because with rare exception..you can't get them over the counter anymore.  They're known carcinogens..with repeated exposure.  Also well known to cause liver and brain damage if inhaled or allowed to soak through the skin repeatedly.  One of the main reasons they were withdrawn from market..is due to high incidence of liver and brain damage in workers exposed over time.  Like so much of the old stuff we used to use..get great results from..methylene chloride..et al. (as with leaded gas and paint..certainly with cyanide..PCB's) have been found to be just too hazardous for common use. Certainly nasty stuff from a health point of view.
Would suggest just looking at can for nostalgic reasons.  But if decide to empty contents..you should take to hazardous waste facility..as it's not good at all to dump down drain..or in sewer systems.
Sorry if this sounds like wet blanket..but from years of background as health professional..that's my opinion on this..
Ichi
Al Summers
Present: '77 550K
Online scottly
« Reply #21 on: July 27, 2013, 08:32:17 PM »
I rebuilt a '59 VW motor in high-school auto-shop in my junior year, and I was allowed to use the glass bead blaster at the local college, provided I thoroughly cleaned the block in the school shop first, so as not to contaminate the media. After several days of scrubbing in the solvent tank, the skin on my hands began to dry and crack; turned out the instructor had dumped a couple of gallons of old carb dip into the solvent, thinking it would improve the effectiveness. >:(
« Reply #22 on: July 28, 2013, 11:29:58 AM »
The chemicals in that cleaner is no doubt dangerous and in the past we were all subjected to exposure to anything you can name including mercury. The Dental profession has still not officially banned the use of Mercury fillings.
The small can of carb cleaner used in the proper amount will not harm the motor or anyone else. If fact by using it you will destroy it, think of your motor as a hazardous waste disposal facility. Keep the can it is cool looking. ;D ;D ;D ;D
