Author Topic: '75 CB400F to make pretty again..finished pics  (Read 39274 times)
Offline tweakin
  • tear down
Re: '75 CB400F to make pretty again
« Reply #100 on: March 02, 2014, 07:11:19 PM »
Looks great Larry!  Did you make the chain guard?
Offline nvr2old
« Reply #101 on: March 02, 2014, 09:51:55 PM »
Yeah.  It only took a couple of hrs. of cutting, bending, drilling, sanding and polishing.  1" aluminum stock from Home Depot..  :)
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #102 on: March 07, 2014, 06:11:26 AM »
Great job on that.  Really like how the the tail light fits in the seat back, truly custom.
Looking forward to seeing the meticulous paint!
Offline nvr2old
« Reply #103 on: March 07, 2014, 10:38:30 AM »
Thanks Stev-o.  Painting these parts is what I'm looking forward to, also.  I'm thinking maybe I'll go with a pseudo CBX stripe to go with the stock Varnish Blue.  Black stripe on the raised portion of the top of the tank bordered with 1/8" gold and red pin stripes to match the tank and side cover decals.  I'm thinking of carrying that stripe onto the top of tail and front fender, too...we'll see.  I don't want to stray too far away from the stock paint job too much.  I really want this bike to look like a "what if Honda had made an "R" version of one of these" kinda thing.
« Last Edit: March 07, 2014, 11:01:13 AM by nvr2old »
« Reply #104 on: March 07, 2014, 05:08:07 PM »
Love the Varnish Blue on the 400F's. Any problem matching that color?
FYI - Dirtbike Don is selling Honda paint kits again.
Offline nvr2old
« Reply #105 on: March 07, 2014, 05:41:49 PM »
Already have the paint, but thanks for the tip.  Should be a perfect match.  I really like the blue, too.
Offline nvr2old
« Reply #106 on: March 09, 2014, 10:28:50 PM »
Spent another Sunday in the garage locked away for 8 hrs... I wanted to get this tail section finished and ready for primer next weekend.
A ton of itchy, tedious sanding..but the results are always worth the effort. I changed the stock lines from this Ducati tail a bit. It swoops a little more now.
It would have been so much easier to cut the stock factory seat hinges off, but I really want to leave them on, so these blisters are a necessary evil. They won't show much after the seat is on. I kinda like the curves, though..
I reinforced the 'glass inside along all the edges. It's hell for strong now.
Tail light looks killer..
All of the edges have been rolled and sanded smooth.
I'm really liking the look of this tail section..
On to the gas tank. Pull a few dents, smooth out a couple of dings..should be the easiest part of all.
« Last Edit: March 09, 2014, 10:32:08 PM by nvr2old »
Offline Just4fun
« Reply #107 on: March 10, 2014, 10:54:40 AM »
Larry,
Your attention to detail is awesome.  Looking at the seat and knowing the quality of paint you spray, how do you protect the paint and fiberglass when you bolt through.
Many fiberglass seats I have seen have cracking at the mount points.  I know you have reinforced your seat to eliminate that problem.  I always wondered the right way to mount through a seat like yours to protect the paint because weight on the seat puts pressure on the threads, do you use a rubber grommet or ? to protect the seat?
Thanks
Sent from my iPad using Tapatalk HD
Offline nvr2old
« Reply #108 on: March 10, 2014, 11:58:24 AM »
Larry,
Thanks
You're absolutely correct about the cracking around mounting points.  That's the reason I made sure those areas were reinforced especially at the rear mounts and the seat pan.  I also made the mounting holes just the size of the bolts I'll use so the tail doesn't move.  Moving around, flexing, and thin fiberglass is what makes them crack.  This one is solid as a rock at every mounting point and it sits right on the frame under the seat pan.  I'll probably use a thin rubber strip (strips of inner tube, possibly) under the seat pan where it sits on the frame, and rubber washer and a metal washer between the rear mounting points just to cushion it against the new paint when it's tightened up.
« Last Edit: March 10, 2014, 12:10:05 PM by nvr2old »
Offline nvr2old
« Reply #109 on: March 16, 2014, 03:22:27 PM »
This will probably be the last update for awhile until I can get going on the paint. All the body work is done, parts are just about ready for primer. Just a little more hand sanding to do.
I learned long ago never to throw anything away that looks like a bracket. I don't even know what this came off. I had two of them and was digging around for something to make a license plate hanger out of and came across them in a box-o-stuff.
With a little bending, a couple of holes drilled in the back of the tail light housing to connect them, and a piece of 1" aluminum strap..viola..
Wished it was a 1/4" longer, but it should work. Clean, simple.
Got the tail light mounted and the turn signals, too. Had to recess the turn signal posts into the fiberglass to get them to sit 90 degrees to the frame. Deeper on the front end, otherwise they were bent in and looked weird.
Pulled the dents from the front of the tank until they were just a little low and skim coated them with filler. Fixed a few dings here and there and it's ready to prime. Still need to sand the underside by hand.
Got some cheapo bar ends off eBay. They actually work pretty well after "modifying them" so they'd spread open enough inside the bars to tighten down..
Overall I'm pretty happy with the results. Can't WAIT to paint it. This next week I'm gonna focus on the seat.
Offline tweakin
  • tear down
« Reply #110 on: March 16, 2014, 03:28:01 PM »
That looks great Larry!  Excellent work as usual.
Offline nvr2old
« Reply #111 on: March 16, 2014, 03:50:06 PM »
Thanks, tweakin..gettin' close...  Should be done by the end of next month if all goes according to plan.
« Reply #112 on: March 16, 2014, 03:58:22 PM »
Nice prep work on the tank nvr2old.
Offline nvr2old
« Reply #113 on: March 16, 2014, 06:15:48 PM »
Appreciate the compliment.  It took a really hard whack to that side of the tank.  The dents were the perfect outline of the fork tube and the triple clamp.  Must've broken the fork stops, but someone did a nice repair.  It's not a problem now.  The tank was fun to do.  It's nice and straight now.
Offline nvr2old
« Reply #114 on: March 29, 2014, 05:21:40 PM »
Not a ton-o-progress, but I did get everything primed today. It gives me a better idea of how all the parts work together. Wasn't sure how the newer front fender and the Ducati tail would really look with the stock tank and side covers until it's all one color.
I'm thinking the tail looks to droop a bit, so I'm hoping I'll be able to visually correct that with the paint scheme I have in mind..we'll see..
I'm pretty stoked about the tail section overall though. It hasn't even been block sanded yet and it's looking nice and straight already..
Just sprayed them a few hours ago, so I'll let them cure for a few days then start on them with some block sanding. One more prime, then they'll be ready for color. Can't wait..
« Reply #115 on: March 29, 2014, 05:44:33 PM »
Looks good!
Offline RainsongCB750F
« Reply #116 on: March 29, 2014, 06:14:26 PM »
This is a beautiful build. I can't wait to see it complete. Keep up the good work :)
Sam
« Last Edit: March 29, 2014, 06:17:55 PM by RainsongCB750F »
1978 CB750F
When Jesus comes back he will ride an SOHC4.
Offline nvr2old
« Reply #117 on: March 29, 2014, 07:01:25 PM »
Thanks, guys.  I'm anxious to get it done, too.  The paint should really bring it all together.
« Reply #118 on: March 29, 2014, 07:15:55 PM »
Nice Work  :) Did you ever do body work as a profession ?
Offline nvr2old
« Reply #119 on: March 29, 2014, 10:20:44 PM »
Yeah, I did, check the link at the bottom of my post..thanks for the interest.
« Reply #120 on: March 30, 2014, 05:45:39 AM »
Larry,
I looked at that link and after reading this thread I have to agree that "prep is everything"  ;)
Offline nvr2old
« Reply #121 on: March 30, 2014, 10:50:10 AM »
Larry,
You're absolutely correct.  The paint shows off the prep work.  If it's done right, it can look spectacular.  If the prep sucks, no amount of shine or pretty color can hide it.
« Last Edit: March 30, 2014, 10:52:07 AM by nvr2old »
« Reply #122 on: April 11, 2014, 05:33:20 AM »
Got color yet?
« Reply #123 on: April 11, 2014, 09:59:29 AM »
I like the look of the stock blue myself  :)
Offline nvr2old
« Reply #124 on: April 11, 2014, 10:35:00 AM »
Thanks for the bump, gentlemen.  Hard to stay on the front page w/o daily updates.. :D
I'm going to prime all the parts again tomorrow after block sanding them once already.  They look great.  I should have color, stripes, and clear in the next couple of weeks.  The Varnish Blue is a very cool color.  I won't change it much from stock..just enough to make it a bit different.
I did manage to get a seat pan fabricated, so now it's time to also get the seat foam and shape done for the upholstery guy.
Thanks again for the interest.
