Author Topic: Mounting modern calipers on Ceriani Roadrace forks  (Read 7637 times)
« on: August 02, 2013, 10:51:13 PM »
 Also known as GP forks, I mean the 35 mm version.
 I am mounting a 6 piston caliper to a big floating disc. Bad part is the fork legs at the  point where the caliper fits is only 5 inches wide The 6 pot calipers are pretty wide from the disc inwards, which leaves little room
 I think I have it sorted, and will have it done soon. I think unless you had a seriously slimmer caliper, it would be very difficult to make it work with a wire wheel.
 I am only running one caliper, and rotor, will let you see how it works out.
 Anyone ever done this before?
Offline Jim F
  • go baby go
Re: Mounting modern calipers on Ceriani Roadrace forks
« Reply #1 on: August 03, 2013, 10:38:14 AM »
this is my set up using 6 pot calipers, I had to machine the back side of the calipers to clear the spokes (I tried to match the angle of the spokes)
so much that I machined into the piston pockets. its nice to be able to just weld them up but there is not
a lot of room left. The front end is a GL1000 and the rotors are from an RC51 Honda
on the other hand I machined the mounting tabs on the forks to move in the mounting plates to make these work
320mm brembo rotors using EPM wheels
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #2 on: August 03, 2013, 03:39:55 PM »
Do you have mounts on the fork legs already Frank..?   I have to weld mounts on mine...
« Reply #3 on: August 03, 2013, 08:39:43 PM »
I have mountsbut will not rely on two 6 mm bolts, so i will tie it into the bottom.
 Here is what I got..
« Reply #4 on: August 03, 2013, 10:43:06 PM »
So your happy welding the fork legs..?Mine were welded on one side a long long time ago, I need to grind those mounts off and have new ones fitted..  Are those sliders in the pic, up threw the triple clamps some..? if not my forks {tubes}are longer than those..
« Reply #5 on: August 03, 2013, 10:55:57 PM »
I try to avoid welding at all costs.. Your legs are thinner than you think. If I told you how thin,you would probably measure them, before you believed me.
 If they warp how will you clean up the inside bore and keep it straight? Easier on thicker legs.
 I would use machined split mounts for fender or brake if they were missing.
 This set is my buddys, mine have the double mounts.
The springs are out right now.
« Reply #6 on: August 03, 2013, 11:19:28 PM »
The mounts on them now have been tigged on so i know it can be done, I also understand what you are saying, I planned on taking them to a local engineer I know to have a look at them first, he says he can tig anything so i'll see what he thinks before i do anything.... If its all too much drama i'll sell them and use something else.
Offline simon#42
  • liverpool
« Reply #7 on: August 04, 2013, 02:05:23 AM »
i wouldn't weld them either mick , bought a set of M I R forks a few years ago that had been welded . it looked a beautiful job but the slider had distorted , ended up making a steel sleeve which i pressed in and then had it bored straight . of course i then had to alter all the bushes etc  to fit .  there are some jobs you wish you hadnt started !
« Last Edit: August 04, 2013, 02:10:07 AM by simon#42 »
« Reply #8 on: August 04, 2013, 06:32:23 AM »
I have experienced the same thing
« Reply #9 on: August 04, 2013, 02:53:17 PM »
Hmmmmmm.....looks like i'll have some cerianni's for sale then, they only have a caliper mount on one side and I'm going twin discs {wouldn't ride with one disc at all on an old cb}. Back to the drawing board....  Anyone know what the diameter of Boldor fork sliders  are.?
« Reply #10 on: August 04, 2013, 04:33:10 PM »
Just run a good caliper, and mount top and bottom like We are doing.
Not sure but I am thinking at 90mph it should stop good once..but not repeatedly..could be wrong..
« Reply #11 on: August 06, 2013, 10:01:49 PM »
I think. This fork will use upside down K&N Superbike bar..upside down...looks cool..
 Brake mount is almost done..
« Last Edit: August 06, 2013, 10:05:34 PM by 754 »
« Reply #12 on: August 06, 2013, 10:08:19 PM »
The brake mount  bar ties into fender mount and the lower fork pinch bolt.. Should hold that 6 piston brake..
 Got a pic of the nearly finished mount, but it wont load up.
« Last Edit: August 06, 2013, 10:11:56 PM by 754 »
Offline johno
« Reply #13 on: August 07, 2013, 05:45:35 PM »
Retro what does this no one disc thing mean ?
Are you going soft in the balls department  :o  or have you bulked up and more kg needs more disc ::) ::) ::)
Either way its usually age related.  ;)  Take Young at heart Sam for example, he used to race over a mile, then quarter mile, now just wants to throw his leg over a bike.  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Can you see whats happening Retro , stick with your trusty philosophy, just put the best forks and brakes you can afford on. ;D ;D ;D    polish it up, take it out for a nice warm up ride winding through the hills then on the way home, stop at a nice quiet spot, grip on well, big rev dump clutch and smoke out a big donut, when the bike lines up with the road just continue to rev the F#ck out of it smokin up the road, after it hooks up and things settle down punch the air with your fist and think yeh I'm still running this show..................cos for a lot of us mature gentlemen that choice gets taken away from us so as my wise mom said to me just before she passed away .....if the parts still work use them.
Thought for the day Grasshopper !  dont worry about slowing down just worry about going faster. ;D  slowing down comes naturally.
« Reply #14 on: August 07, 2013, 07:17:03 PM »
I've always been a demon on the brakes Johno, it was my advantage when i was younger {and faster} love good brakes so no compromises my friend.... ;D
Offline Ricky_Racer
« Reply #15 on: August 07, 2013, 07:47:37 PM »
Retro, this is how they're normally done. RR
« Reply #16 on: August 07, 2013, 09:41:46 PM »
So they use what i thought were guard mounts as mounts for the caliper bracket, sorry, i don't have my reading glasses with me but thats what it looks like.... ;)
« Reply #17 on: August 07, 2013, 10:33:50 PM »
 I think the 310?mm Duc rotor,and Tokico 6 piston will stop at least as good as that..
Offline Tintop
« Reply #18 on: August 08, 2013, 04:21:45 AM »
Those are the threaded holes for mounting the brake stay for a drum, set each side for a 4LS drum.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #19 on: August 08, 2013, 08:10:41 AM »
Some have double lugs , on each fork leg, 4 holes on 2 mount bosses. I have  set of them.
Offline Ricky_Racer
« Reply #20 on: August 08, 2013, 10:23:01 AM »
And some later versions are made with cast-in mounts for fitting dual calipers in the AP Racing or Grimeca size. RR
Offline Tintop
« Reply #21 on: August 08, 2013, 12:26:30 PM »
Agreed there is more than one version that was produced.  Was referring to the ones on the picture, which appear to be drum legs converted to disk.
77 CB550 Cafe build
« Reply #22 on: August 08, 2013, 03:17:04 PM »
Almost every dragbike that used them mounted discs to the GP or roadrace forks,and that is a lot of bikes. THe RC Eng A,T,&SF...used that fork... They seem strongm considemring how light they are built.
Offline BPellerine
« Reply #23 on: August 08, 2013, 04:25:22 PM »
handelbars below the top tree Frank gulp!ha bill
1978 CB 750K ard and webers
another anfob
« Reply #24 on: August 09, 2013, 02:38:37 PM »
Here it is pretty much done,a bit of trimming on the lower mount, and ready to polish.
.should stop pretty good.
