Author Topic: Any idea how to fix this... sigh  (Read 1430 times)
Offline Moffman
  • 1979 Honda CB650
« on: August 04, 2013, 01:52:23 PM »
Welp, I pretty much hate myself right now. Removing the carbs off my '79 CB650 (I just bought that was sitting for a while) and even though I tried being as gentle as possible and made sure I didn't scratch a single thing I still managed to break something. After manhandling the carbs a bit I was able to start tilting them out. As I was pulling out I didn't notice the choke cable attachment bracket that is plastic, I guess was caught on something because I heard a snap. My heart sank into my stomach. Surely it was just a cable getting out of the way I thought but nope. Here is what I'm dealing with. At least it wasn't for nothing as the carbs are full of gunk.
The only thing I can think of is JB weld, but I really don't want to just rig it back together. Any ideas?
Offline davesee
Re: Any idea how to fix this... sigh
« Reply #1 on: August 04, 2013, 02:26:17 PM »
if it were me i'd try and rig up a little brace for it along the break and epoxy it back together. then i'd hunt for a used one, or try to fab up something out of metal. i feel your pain.
1980 honda cb650 with many weekends worth of modifications.
Offline Garryk
« Reply #2 on: August 04, 2013, 02:40:24 PM »
JB Weld's prob the only thing that would hold it,try David Silvers Spares im sure they'll  have the part you need,if you don't find it on their site contact them.
Good luck.
Garryk
Offline wowbagger
  • Not much of an
« Reply #3 on: August 04, 2013, 02:47:43 PM »
Send harisuluv a PM. He rebuilds these a lot so he'll know where to get replacement parts. He may even have something that will fit.
Offline Moffman
  • 1979 Honda CB650
« Reply #4 on: August 04, 2013, 02:53:44 PM »
Good luck.
Garryk
If it did decide to replace the part, would it involve splitting the carbs because its hard to tell how it would come off otherwise.
Will do thanks.
Yeah I think I'll probably JB weld it for now, I just hate it when something like this happens and the entire bike feels "broken".
Offline BPellerine
« Reply #5 on: August 04, 2013, 06:03:49 PM »
yeah I know that feeling it sucks!bill
1978 CB 750K ard and webers
another anfob
Offline Dimitri13
  • 1974 CB550K
« Reply #6 on: August 04, 2013, 06:20:20 PM »
You should be removing the carbs from the rack to clean then regardless.
Offline fmctm1sw
« Reply #7 on: August 04, 2013, 06:31:56 PM »
Don't feel bad.  That little plastic thing has reared its ugly head around here a number of times now...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Moffman
  • 1979 Honda CB650
« Reply #8 on: August 04, 2013, 08:36:29 PM »
Some pics of the insides of the carbs if anyone was curious.
Offline blakes1975
    • n/a
« Reply #9 on: August 04, 2013, 10:54:48 PM »
if its plastic i had to fix my k&n and used epoxy called     2P-10     the glue is in a little tube like crazy glue and then you get the spray can that causes it to harden in seconds. let it cure and good as new.
Offline trueblue
« Reply #10 on: August 05, 2013, 02:58:54 AM »
I had the same issue with my 650, I found a set of PD's off a 750 that were knackered, they had a metal version of that little lever.  I just had to unrack the carbs and swap it over.  It was a direct fit ;D.
1979 CB650Z
« Reply #11 on: August 05, 2013, 04:47:56 AM »
Plastic sucks !!  How much did Honda save on that part,a penny  ::) I know somebody will do the math and throw out a big figure but Jeeeesh
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #12 on: August 05, 2013, 07:41:00 AM »
Don't believe this part failure was because it was "sucky" plastic. Owner error on removal is this issue on this thread. The plastic "was OK" for 34 years on this part prior to the error.  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #13 on: August 05, 2013, 07:50:31 AM »
Good point --  but it sure seems like I have to fix a multitude of gizmo's,gadgets and other things with broken plastic bits
Offline fmctm1sw
« Reply #14 on: August 05, 2013, 05:37:57 PM »
At any rate, Honda must have rethought it because on both my '81s that part is back to metal..
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #15 on: August 05, 2013, 07:14:01 PM »
If you do jb Weld it, if you can snaek a really thin nail or stiff  wire between the two pieces with the jB around it, i will be strong
Offline lucky
« Reply #16 on: August 06, 2013, 02:38:07 PM »
Bike Bandit may have that part. It is worth checking.
