Author Topic: Fork Gaiters Not Fitting  (Read 974 times)
Offline acb
« on: August 26, 2013, 08:49:33 AM »
I'm reassembling the forks on my 73' CB750K after doing a fork seal job and the fork gaiters don't seem to fit over the bottom end of the forks anymore.
The previous owner had taken the gaiters off and was just using rubber fork caps – I'm assuming the fitment issue is because the gaiters are original, have been off the bike for a while and have hardened a bit.
Just wondering if anyone has run into this issue before and has any advice before I spend $60+ on some new OEM gaiters.
Any help is much appreciated.
Thanks
Offline 750K
Re: Fork Gaiters Not Fitting
« Reply #1 on: August 26, 2013, 09:00:13 AM »
I'd try a blow dryer or heat gun to soften them up and help them stretch over the fork lowers, if they crack or rip then buy new ones.
77 Cb750, 78 Kz1000
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #2 on: August 26, 2013, 09:20:08 AM »
I put new ones on my 550, and they definitely were tight. Warming them up should allow them to stretch a bit.
Offline acb
« Reply #3 on: August 26, 2013, 01:13:40 PM »
Thanks for the help, I had tried heating them already but I'll give it another shot. Good to know that even new ones will fit tight as well.
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #4 on: August 26, 2013, 02:06:00 PM »
I gently hit mine with the heat gun, then flipped the end over on its self inside out, pushed it down the tube then flipped it right side out onto the lower fork. Worked like a charm.
'73 CB500 upgrades a'comin
Offline Johnie
« Reply #5 on: August 26, 2013, 02:24:56 PM »
Make sure you have them orientated correct as there is a top and bottom to these.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline SohRon
« Reply #6 on: August 26, 2013, 03:26:21 PM »
+1   And a front and back as well!
Offline wowbagger
  • Not much of an
« Reply #7 on: August 26, 2013, 03:48:24 PM »
+2 and an inside and an outside too ;) ;D
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #8 on: August 26, 2013, 08:51:45 PM »
Unless your a purist who has to have OEM and you determine you need replacements the online store from Florida; CB750 Supply hooked me up with a set for around 20 bucks that were a good fit, soft and easy to install.  I put them on my K1 550 (same as 750) more a year ago and haven't seen any cracks or degradation so far.  They don't feel quite as heavy as stock but for the price I was happy.  I had previously purchased a set from a online source that advertised stock fitment but when I received them they turned out to have a set of cheesy steel hose clamps meant to hold them at the top.  Avoid those!  They are junk out of the box.  I dealt with a lady named Vickie.  Good to do business with.
http://www.cb750supply.com/
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
