Author Topic: Polishing Fork legs - Been wanting to do this for years.  (Read 3998 times)
Offline CR125Honda
« on: September 02, 2013, 10:23:24 AM »
Doing a front end refurb. Brake master & caliper rebuild, steering neck bearings, touch up paint, etc..
Thought now would be a good time to knock this out.
One down, one to go..
Started with 220 grit on a triangle shaped palm sander, all by wet hand sanding after that. 400, 800, 1200, 1600, 2000 then a little polish.
Ken
« Last Edit: September 02, 2013, 10:45:46 AM by CR125Honda »
1974 CB750K4
1974 Kawasaki H2
1970 Triumph 650
1961 Pan/Shovel
Honda Benly 125 Touring
2003 BMW K1200LT
2005 Yamaha R1 Raven
1975 CR125
Ct70's, QA50's
Re: Polishing Fork legs - Been wanting to do this for years.
« Reply #1 on: September 02, 2013, 11:08:49 AM »
Pure porn, man  :)
Offline RSchaefer
« Reply #2 on: September 02, 2013, 11:35:13 AM »
Are you going to clearcoat that now?
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #3 on: September 02, 2013, 11:55:31 AM »
Nice job.....love polished aluminum
Offline CR125Honda
« Reply #4 on: September 02, 2013, 02:43:03 PM »
RS,
Yes, Think I'd like to clearcoat this time but have never done that before.
Every other polish job I've done I've just kept it clean & polished over the years until it needed touching up again.
Any recommendations on how to prep for a clearcoat?
I used a Semichrome type polish and assume I'c need to get the polish and any other impurities out prior to paint..
Ken
1974 CB750K4
1974 Kawasaki H2
1970 Triumph 650
1961 Pan/Shovel
2003 BMW K1200LT
1975 CR125
Ct70's, QA50's
« Reply #5 on: September 02, 2013, 02:44:22 PM »
Maas polish has a nice protective finish to it that will give you enough protection you only need to touch it up 2-3 times a year. I really like it and use it on my polished stuff.
Stev-o has some stuff I polished for him that I used it on...
Should still be looking very nice, especially since it has been sitting and not exposed to the elements.
David
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: September 02, 2013, 02:44:33 PM »
How long did it take to polish that?
Offline john campling
« Reply #7 on: September 02, 2013, 02:49:38 PM »
Polished ally looks good just sprayed with ACF 50
Aircraft spray in a can like WD40 but is an anti corrosion thing
Dont know how well this would work on fork legs but people use it on engines
Seeley CB750 1976
BSA A10 Cafe
BSA A10 Plunger
BSA Super Rocket Street Scrambler
Yamaha SRX4
RE 250 cafe
Honda CB-1 400 '89
Yamaha TY175
Triumph T90 '68
Yamaha Fazer 600 '99
Offline CR125Honda
« Reply #8 on: September 02, 2013, 02:54:07 PM »
David
Thanks David,
I'll look into that. It's no hanger queen so it will be exposed.
I've seen how the clear starts to yellow & chip after a while. Going to weigh the options on how to protect it.
Ken
I'm guessing 6 hrs..  Most time is spent with the palm and small triangle sander & 240 grit. The next wet sand with 400 by hand takes a fair amount too. The next steps (800-2000) go a bit quicker.
Thanks, Johniie,  Will look into that too.
Ken
« Last Edit: September 02, 2013, 02:56:43 PM by CR125Honda »
1974 CB750K4
1974 Kawasaki H2
1970 Triumph 650
1961 Pan/Shovel
2003 BMW K1200LT
1975 CR125
Ct70's, QA50's
Offline RSchaefer
« Reply #9 on: September 02, 2013, 02:58:52 PM »
I was going for the stock look rather then a full polish
Original:
Trying to get the stock look:
Then I powder coated clear:
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #10 on: September 02, 2013, 03:03:53 PM »
I've decided that the 220 is best skipped unless you have scratches you need to remove...the rough casting being an exception for this area if you want to smooth it. Just takes you more time to work out any scratches left by the 220 that it is worth.  320 or 400 yields better surface with similar work.
8 hours isn't unheard of for a fork leg.  I spent more time than that doing hand detail work on a caliper getting into nooks where it was difficult to reach.
Polishing is messy work, you have black dust from the compound everywhere any your face and hands and arms are covered in it. Good idea to have eye protection and wear a dust mask when doing it...not good for your lungs to not to.
Oh, BTW, blue painters tape or duct tape can protect the aluminum when sanding areas you don't want scratched with the coarser grades of sandpaper...can save some work with a few minutes of taping. Just replace the tape when you start cutting through it...
David
« Last Edit: September 02, 2013, 03:25:14 PM by RAFster122S »
Offline fastbroshi
  • Puppet
« Reply #11 on: September 02, 2013, 08:14:02 PM »
Love the finish, even up close it looks good.
Just call me Timmaaaaay!!!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #12 on: September 03, 2013, 10:36:36 AM »
I did this on my GoldWing and the '75 550K forks this summer. It's not as difficult as one might think, but it is messy and time consuming. I would say a solid 2-3 hours a pair.
The only power tool I used was a drill with the buffing wheels for the final polishes. I finished with red, then white rouge and a final polish with simichrome.
I'm not going to clear either of mine. The clear will yellow over time and it's not a big deal to polish them a couple times a year to retain the finish.
Offline RSchaefer
« Reply #13 on: September 03, 2013, 10:45:09 AM »
I'm going to be interested to see how mine hold up with clear powder coat.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
  • 1977 CB550F2
« Reply #14 on: September 03, 2013, 12:17:49 PM »
I've never been satisfied with any clear over alloy I've done. I always use chrome cleaner when I clean my bike so the finish stays pretty good.
