Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 273811 times)
Offline edwardmorris
  • Youngish
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- ENGINE TEARDOWN
« Reply #175 on: December 31, 2013, 08:50:25 PM »
It looks like someone has "hemi'd" that head. If you can afford it, maybe consider having it milled a little bit to raise the compression back up. Measure the depth of the edge of the intake valve from the deck surface (with calipers), to see if it is more than 3mm. If so, maybe consider milling some of that off?
Doesn't look like there is much left, what do you think?
  • Youngish
« Reply #176 on: December 31, 2013, 08:52:51 PM »
Exhaust side is worse, maybe it was done to balance the head?
« Reply #177 on: December 31, 2013, 09:24:03 PM »
It's a little hard to tell without the valves (intake) in place. Sometimes they sit down in the seat, sometimes more toward the chamber. Stick 'em in, maybe post another pic? That would tell better. It's possible someone already milled it?
  • Youngish
« Reply #178 on: December 31, 2013, 09:42:19 PM »
I will clean up the valves, put them back in and post back. Two of them are bent, or the guides are bad, should I just grind the tail a little and push them back in or leave those two out?
« Reply #179 on: January 01, 2014, 12:05:01 AM »
Looks good Ed, but I wouldn't take any more metal off it, have you measured the valves? It could be that they're a tad bigger than stock? When you take more pics, shoot one into one of your inlet ports with the valve out, I'd like to see if someones reshaped the ports?
More than likely your valves aren't bent, but the tips have mushroomed slightly and are tight in the guides. If you've got a dremel tool with a sanding drum attachment, run it around the tips of the "bent" valves above the collet recess, just little bits at a time until the valves slide into the guides smoothly.
To test if they are bent, chuck them in an electric drill and spin them, if they're bent, you'll see it straight away. Cheers, Terry. ;D
  • Youngish
« Reply #180 on: January 01, 2014, 11:14:49 AM »
What better way to start the new year than shoveling snow? Was hoping for better lighting outside but these still look crappy. Slightly better views of Gordon's kit
  • Youngish
« Reply #181 on: January 01, 2014, 11:20:38 AM »
Back to the head
@Hondaman: Pic 1 is #4 inlet and Pic 2 is #1 inlet. The measured a miserable 1.95mm and 1.82mm respectively from the edge of the valve to the edge of the flat surface.
@Terry: Did the drill test for the valves yesterday and all of them have a little run out, but the two bad ones are beyond saving. Looked closely at the tips, not one has mushroomed. The length is 4" on an inlet valve that I had cleaned. Are they all the same length or should I clean one of the exhaust ones and measure it? Doesn't really matter I suppose, will definitely need new ones.
So the question again now is should I upgrade to bronze/brass guides as well?
Offline BPellerine
« Reply #182 on: January 01, 2014, 02:14:20 PM »
if this engine was running with bent valves I would have to think that the guides are shot .are you sure that it would not be better to start with a better head in your case they must be fairly common?bill
1978 CB 750K ard and webers
another anfob
« Reply #183 on: January 01, 2014, 02:30:11 PM »
Bill's got a valid point Ed, if money is tight, new valves alone will burn a hole in your pocket. While I've never seen inlet valve guides worn out, you can buy bronze guides pretty cheaply, so if you're buying new valves as well, then you should replace the guides.
Be careful though, I bought some new bronze guides for the engine I just finished building, and while the clearances were fine on the exhaust valves, they were way too tight on the inlets so I had to knock 'em back out and reinstall the old OEM inlet guides as I didn't have a valve guide reamer on hand when I did them. Cheers, Terry. ;D
  • Youngish
« Reply #184 on: January 01, 2014, 05:49:11 PM »
Thanks BPellerine, my concern with a used head is I might run into the same problems all over and I'm inclined towards suggestions made by many helping me out, which is to save up and do it right instead of having it croak when I'm on the road. I'd gladly save up and take it to a shop if a local one agrees, but its the shipping to far away places (granted excellent work) is what is killing me. I want to keep that as a last resort. I've learnt that nothing will happen overnight, so I'll take my time to save up and get new and correct valves, springs, guides and seals and if necessary send it away.
I took the pics of the inlet port with the valve removed for you Terry, hope this is what you needed.
  • Youngish
« Reply #185 on: January 01, 2014, 05:55:12 PM »
I started cleaning the jugs today, what a tedious nightmare scraping off the lower gasket is. Brought it down to Pic 2 and quit for now. Used so much elbow grease, feels like I'm getting a tennis elbow. Any tips on getting the last really burnt in bits off without hurting anything?
Pic 1 shows the top side, as I was cleaning I noticed that there is a rim of carbon/soot deposited at the edge. Is this normal? I wan't to work on getting the paint off of this thing too, so is it ok or stupid to try and remove the jugs?
Offline BPellerine
« Reply #186 on: January 01, 2014, 07:23:16 PM »
not trying to steer you away from doing things right but just the amount of thread damage combined with the head being modded by someone unknown would give me pause.I live in Canada so I know all too well the cost of shipping and getting parts.I would have to think that in the states you could get a GOOD used head worth putting the money into I know in Canada this is fairly easy to find but I don't know about your area.just my thoughts bill
another anfob
Offline Davez134
« Reply #187 on: January 01, 2014, 08:06:11 PM »
To clean mine up, I soaked the surface in a shallow pan of sea foam that I had lying around for most of the day, then i scraped with this hard plastic scraper I had lying around, seemed to come off fairly easy. If you are talking about the ring of carbon at the top of piston travel, I had those on mine as well. I soaked that side as well and used the plastic scraper again to remove the deposits. After honing, the cylinders look new. If you want to remove the paint, I would look into finding a place near you that does media blasting. The shop that did mine was not very expensive, and they could probably get those deposits off too.
  • Youngish
« Reply #188 on: January 01, 2014, 08:26:26 PM »
Turns out its not even a K2 head.
SCREEEAAAAAAAAAAAAMMMMMM
Was going for a correct resto, now gotta decide which way to go.
« Reply #189 on: January 01, 2014, 08:37:54 PM »
It's not unusual for me to 'spend' 2 or 3 razor blades on a well-cooked bottom side like that. I sometimes soak the whole cylinder set in gasoline (until it evaporates away!) with some Marvel Mystery Oil mixed in, that seems to soften the paper up. There are also paint-on gasket softeners at auto parts stores that will help with this part. It can be tedious, especially if the gasket is OEM, now 40 years old, and they were impregnated with an excellent sealant.
I've also used a propane torch: heating up the gasket until it starts to smoke will reactivate the old sealant and make it tacky-er for a minute or so, which helps. When it cools again, it glues tight! That made them very dry: I wish the equivalent gaskets were still around today.
The carbon on the top deck is an outline of the metal ring in the head gasket. Often, the head gaskets are not an exact match to the bores, because the stock gasket has to fit up to +1.0mm oversize pistons, too. Once in a while I've seen where someone goofed and used, say, an 836cc gasket on a stock cylinder bore or an 811/812cc set: this makes a 65mm size carbon ring that can cause preignition (ping), in real bad cases.
The head: it does look like someone has both milled it before, and 'hemi-ed' it before. That was the correct thing to do, at the time. If it has a bent valve, I'd suggest the following steps, as this would be my 'checklist' if I had it here:
1. Take the engine's bottom end apart (this doesn't imply you haven't, it's just my method), and check for the rounded gear dogs (and slots) on the C2-C5 gears. These are the first 2 gears that are by the removable bearing on the left side of the engine: the C2 has to come out before the countershaft can be removed. Reason: if the dogs and slots here are worn, it likely caused a missed 1-2 shift, which may have been the incident that caused the other damage (pretty common). In almost every engine I have received to fix a bent valve, these gears were worn like this, and needed to be fixed up. APE (Big Jay and Company) does a wonderful job of it.
2. Replace the cam chain and tensioner hardware (rollers, etc.) as they received a mighty snap when the engine stopped so suddenly that day. They are very likely damaged from that event.
3. Check the rod bearings under the bent valves. They might have been hammered oval by the event. You can Plastigage them in 2 different places, 90 degrees apart, to "see" the shape - one spot will show larger clearance than the other, usually by about .0004" or so. New bearing shells fix this one back up.
4. Replace the valve guide(s) where the bent valves showed up. They are cracked (or will be soon), bet on it. The cast iron/Stellite in the pre-1974 heads was hard as nails and brittle as glass. In most instances, there will be a chip on the guide at the port side, usually toward the center of the head, from the event. This shows where the crack starts, has to be out of the head to see it all.
5. If you want to just replace the guide(s) where the event(s) happened, this is OK if the others are not worn out. This was the standard Honda shop repair, back in the day. It's more common today to replace all the guides simply because so many of these bikes have a zillion miles on them, and they are worn - and, the bronze guides we can get today put up much better with the ethanol-laced fuels we suffer. I keep some stock Honda iron guides for those situations: Honda still sells them, and they are pre-sized 98% of the time so you can just install them and lap in the new valve. The only caveat: once in a while the hole where the guide fits may have been tweaked a bit out of alignment from the impact event. In this case, a new valve seat must be cut, as the new angle will not allow the valve to seat. I've even seen where someone used too big a hammer to remove the old guide (instead of heat & cold finesse) and this tweaked the angle, too. Don't do that...
« Reply #190 on: January 01, 2014, 08:45:50 PM »
Definitely not: it is a K4-style head. The cylinders are K2 style, though. The K2 head, like the K0-K3 early types, have a curved front top fin, where yours is a trapezoid shape: pic of my K2 head shown below. Note the front top fin shape (bottom side in the picture), that's the outward 'ID' mark.
  • Youngish
« Reply #191 on: January 01, 2014, 08:56:00 PM »
Sigh, I guess I will hunt down a new head (already started). Will the rocker arms, cam shaft, etc still work with a proper K2 head?
Offline BPellerine
« Reply #192 on: January 02, 2014, 11:50:51 AM »
Edward you should take the member up on the offer for the free stock cam and springs your cam towers should fit and you will be back to stock when you get another head .start from a stock baseline and then decide if you want the pleasure or pain of perf gear however you look at it.you could set all the perf stuff aside till you get things under control.bill
another anfob
  • Youngish
« Reply #193 on: January 02, 2014, 12:14:49 PM »
Already arranged, have a lead on a better head (minus towers) as well. I hope this is the last thing that is out of place on this bike. Managed to scour pretty much all of the K2 stuff, have a lead on the handlebars as well. Anyone see anything else that is off? I can take as many pix as you need me to. Almost have the baseline now, unless I find something chaotic within the cases.
Offline Kickstart
« Reply #194 on: January 02, 2014, 03:41:20 PM »
You may want to consider just getting a whole engine (if you can find one for not too much).  I'm not sure what the going price is for a solid, k1/k2, engine - but it may be worth posting a WTB for one.
Reading Hondaman's post below, I'm also wondering if there may be more problems lurking in your engine.
Don't mean to bum you out, I'd just hate to see you get the new head and parts only to find out you need you need to replace a bunch of stuff inside the engine.  Of course, getting a replacement engine takes some of the fun out of project and it's less of learning experience... but something to consider.
Did you do the checks Hondaman suggested?
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
Offline BPellerine
« Reply #195 on: January 02, 2014, 04:26:17 PM »
these bottom ends seem pretty tough so your stock head should get you a lot further along.and be easier to deal with.hope things go better!bill
another anfob
« Reply #196 on: January 02, 2014, 06:43:03 PM »
The engine I just rebuilt was trashed by a PO, so I had to replace around 50% of the larger components, but my experience is that generally, most CB750 engines that I've opened up have been in pretty good condition overall.
Sorry about your woes Ed, if you need funds to buy a good used head I'd be interesting in buying your K4(?) head, cam, springs etc. Cheers, Terry. ;D
  • Youngish
« Reply #197 on: January 02, 2014, 07:20:00 PM »
Thanks Bill and Terry for your kindness. I'll be able to save up as I start racking up hours with the new year. What is upsetting is the time I'm losing. And of course, when I have it on the road, all parts left over will either go back to members here or to my next project if I may dare dream so. Damn that sexy black and polished engine of yours Terry, that's going to drain my wallet next winter I tell you!
Some good yet expensive news, I've secured a K2 head that came right off a running bike, should be here next week sometime. Also have a stock cam and springs coming in soon from Whaleman, can't wait for the goodies and can't thank you guys enough. I will keep it moving along. I lost a day today because we got buried in the snow here, had to keep shoveling every so often to be able to have the car get out easily if needed. Still battling the mess the old gasket left on the jugs that are inside the house. The last few bits are pretty stuck on there and really testing my patience. As I clean it up, I notice a few very minor gouges at the corner that was giving me a hard time when I was taking it apart. Its from the chisel extension I had to use to pry it open then but it doesn't look too  bad. I'm sure sanding it is out of the question, so suggestions welcome on how to fix (if at all it needs to be fixed).
@kickstart I haven't had time to look into the crankcase yet, its in the garage which was blocked all day by about 18" of snow that I just got done shoveling out of the way. Soon though, hopefully.
« Reply #198 on: January 02, 2014, 07:33:03 PM »
No worries Ed, have you got access to an oven? I heat my oven in my garage to around 200 deg C and shove the cylinder block in the for an hour, then the sleeves will just fall out.
I've got a 3M nylon "strip disc" on my sander/polisher that will remove the old gasket material in around 10 seconds without removing any aluminum, and I soak the cylinder block in Acetone, or layer on some paint stripper, which will remove the paint, grease, carbon, dead mice, etc.
Then I just heat it up and drop the sleeves back in again. If you've gouged the gasket surface with your chisel (I hate chisels) you can carefully file the gouge, just don't go lower than the gasket surface. I had to do the same on the black engine due to the incompetence of another "Chiseler"...... Cheers, Terry. ;D
  • Youngish
« Reply #199 on: January 03, 2014, 07:39:57 AM »
Don't have an oven Terry, the wife bakes a lot and will kill me if I taint hers with engine part ;) The head gasket came off clean with just some residue behind that scrubbed off pretty easy. Its the base gasket that is being stubborn, so I think I'll be able to manage without getting the sleeves out. I will pick up a few things on my way home today to gently remove the rest of it. The gouging isn't bad, and thankfully is only on the outside edges of the one dowel corner. I suppose I can carefully sand/plane that out using a wood block and super fine paper like Calj suggested. I've been searching around here and many have suggested sanding the mating surfaces as smooth as possible IFF they aren't warped. If there's warping, no choice but to find a machine shop that won't scream as if they saw a werewolf when you bring in a motorcycle part. The crankcase and jugs definitely have paint on them, so its good to know I can use a paint stripper to clean the outsides.
Had to go to work today at -11F, but hopefully it will warm back up to 0F and i'll be able to get some stuff done when I get back.
