Author Topic: Right hand control wiring question  (Read 1728 times)
Offline Icarus
    • Icarus Frames, my bicycle frame building company
« on: September 21, 2013, 04:48:02 PM »
I am rewiring my 1975 CB440f and having some confusion with the right hand wiring.  These should be for the starter,  and off-run-off button.  I know the yellow/red wire goes back to the starter relay thing and I have the black/white going to the coils.  Do the black/black double wires just go to power?  Where does the black/red go?
Oh and the black/black and black/white originate from the upper control (kill switch area)
the yellow/red and black/red come from the strarter button area
« Last Edit: September 21, 2013, 04:57:42 PM by Icarus »
1975 CB400F
1977 CB550K
avatar is a previous moto project
Offline Vinhead1957
Re: Right hand control wiring question
« Reply #1 on: September 22, 2013, 04:43:58 AM »
The black white powers the coils.  Comes in black to kill switch goes out black/white.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: September 22, 2013, 05:55:31 AM »
Both blacks have power coming in-one will power black/white and the other power the black/red, which will supply power to the headlight...Larry
Offline lucky
« Reply #3 on: September 22, 2013, 11:17:23 AM »
Headlight, coils, and start.
Black and yellow is the start button wire.
I am in favor of getting two separate switches so that way
 you can turn the headlight on AFTER it starts.
Just remember to turn on the headlight.
Offline Icarus
« Reply #4 on: September 22, 2013, 01:15:20 PM »
Thanks guys.  I have the headlight wire going through an extra switch like you suggested Lucky.  Now I am just trying to figure out why, when I press the starter button, I can hear the solenoid click but the starter doesn't go.  When I connect the two terminals on the starter solenoid it goes.
I got one of the solid state regulator/rectifiers to replace the OEM stuff and still working through other wires.  Does the green just go to ground along with the green from the alternator?  I have the Clymer manual and all the greens, black and crap just goes on and on to power other lights, safety switches so I haven't become proficient at reading these things yet.  Before this I have only wires up a simple Triumph chopper with not electric start, turn signals or warning lights.
I am tempted to just ignore the diagrams and wire things how it makes sense to me and then see if everything works.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #5 on: September 22, 2013, 01:34:37 PM »
When you say connect the two terminals on the solenoid do you mean you are jumping the two main terminals?...Larry
Offline Icarus
« Reply #6 on: September 22, 2013, 01:42:04 PM »
Momo, Yes if I put a wire from one terminal and touch it to the other, the start motor goes.  I just did that to check and see if for some reason the starter was broken.  When I got this bike it had been sitting for ~8 years and it wasn't all together.  It seems like the PO had wired in a momentary button do do just this (jump the terminals) because the button on the handlebars had crapped out.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #7 on: September 22, 2013, 01:52:07 PM »
Disconnect the two smaller gauge wires from the solenoid(one is yellow/red and the other green/red).  Use two jumper wires, ground the g/r and run 12v to the y/r- that will verify that the solenoid is good if the bike starts.  If it doesn't your problem will either be a switch or wiring...Larry
Offline Icarus
« Reply #8 on: September 22, 2013, 03:28:21 PM »
I did what you said Momo and it had the same effect as when I had it wired trough the starter button.  Solenoid clicks but wasn't turning the starter.  I am going to try pulling te solenoid from a cb550 I have here and trying with that one, to see if it's a solenoid failure or something else.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #9 on: September 22, 2013, 03:51:14 PM »
A solenoid can be cleaned fairly easily.  I've taken a few apart, cleaned out, reassembled and they were good to go.  Of course though, if you have a spare it is easy to replace...larry
Offline Icarus
« Reply #10 on: September 22, 2013, 04:46:45 PM »
The solenoid from the 550 had no problems once I wired it in.  Guess I just need to rebuild the first solenoid.  Thanks for your time and patience Momo, it is appreciated.
1975 CB400F
1977 CB550K
Offline MoMo
« Reply #11 on: September 22, 2013, 06:05:35 PM »
No problem, you're welcome...larry
