Author Topic: Front Brake Caliper  (Read 2438 times)
Offline Bradleyjb
Front Brake Caliper
« on: September 25, 2013, 07:37:05 PM »
Recently took my caliper to be sandblasted and powder coated and they blasted the inner portion where the piston sits. Needless to say, I can't get the piston all the way in now. Will the sandblasting cause an issue? Is there any lubricant I can use to get it seated?
Online scottly
Re: Front Brake Caliper
« Reply #1 on: September 25, 2013, 07:42:38 PM »
With the seal removed, the piston should be free to slide in and out...
Offline Powderman
« Reply #2 on: September 25, 2013, 08:17:36 PM »
There's no need to blast inside the bore but I doubt it made the hole any smaller. Blasting will remove a minute amount of material so if anything it would make it looser. No part of the piston should touch any part of the housing at any time. Make sure they didn't get any powder on the lips of the bore.
Offline Garage_guy_chris
« Reply #3 on: September 25, 2013, 08:54:21 PM »
Maybe run a small brake hone down the bore to clean up the blasting? i would think that should clean up the surface.
Offline Dave Voss
« Reply #4 on: September 26, 2013, 07:54:17 AM »
In my experience, sandblasting aluminum creates many very tiny dimples on the surface, where the edges of the dimples are raised above the original surface, thereby changing the overall dimension just slightly.  So, in the case of an internal bore, the diameter is slightly reduced.  Since the clearance between the caliper bore and the piston is fairly small, it doesn't take much change to create an interference, but a small hone for internal cylinders will knock the edges down to restore the original clearance dimension.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
« Reply #5 on: September 26, 2013, 08:15:58 AM »
unless you told them to blast the caliper bore along with everything else....take it back to them to fix it.
« Reply #6 on: September 26, 2013, 10:21:54 AM »
I think I would be insisting the buy me a new aftermarket caliper body from DSS and do it right this time when they powdercoat it.
Offline Powderman
« Reply #7 on: September 26, 2013, 03:59:15 PM »
I think you would be pissing in the wind for that to happen. I, as a coater, would make you prove to me that the piston fit before you brought it to me and that what I did caused the problem. I would hone or sand the bore lip to see if I could make it work. You would be hard pressed to prove it was the coaters fault.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: September 26, 2013, 04:08:45 PM »
Yep, run around the inside with some wetndry and hope that sorts it.
When sending anything out to "others" make sure you deny them all opportunities to f*ck up your months/years of work.
« Last Edit: September 26, 2013, 04:10:19 PM by LesterPiglet »
Offline Bradleyjb
« Reply #9 on: October 08, 2013, 08:39:43 PM »
Ok, I finally got the stuck piston out and removed the inner seal to see, as previously mentioned, that the piston slides in and out of the caliper without the seal just fine. So, it's the seal that's holding it up. Are there any tricks here? It doesn't seem like this should be so difficult...
Sent from my iPhone using Tapatalk - now Free
« Reply #10 on: October 08, 2013, 09:11:21 PM »
Put a little brake assembly lube, just on the piston seal, and slide it in...
Online scottly
« Reply #11 on: October 08, 2013, 09:15:07 PM »
You are installing the piston with the closed end first, right?
« Reply #12 on: October 08, 2013, 09:20:09 PM »
Also make sure the groove that the seal fits in is perfectly clean. A white residue builds up in there that is a major cause of brakes acting sticky. A dremel with a wire brush attachment makes quick work of it.
Offline Bradleyjb
« Reply #13 on: October 09, 2013, 12:36:50 AM »
Haha, yes
