Author Topic: Seafoam = better mileage?  (Read 2479 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: October 03, 2013, 11:54:36 AM »
Why does my bike get better mileage when I have seafoam in the gas?
No seafoam: 22MPG.
Seafoam: 26MPG.
I know these results aren't great regardless, but I always get better mileage when on a tank of seafoam. I am commuting to work in traffic, mostly, and running below 6K RPM most often. Should I just keep the revs up more? I haven't checked for fouled plugs.
--Evan
1975 CB750K "Rhonda"
Re: Seafoam = better mileage?
« Reply #1 on: October 03, 2013, 12:12:09 PM »
check for fouled plugs. do your tuneup.
in spirited riding i still average 38mpg...
Offline mjstone
  • I'm definitly not a
« Reply #2 on: October 03, 2013, 01:08:31 PM »
No seafoam: 22MPG.
Seafoam: 26MPG.
And I thought that I got crappy gas mileage at 35-42 mpg. ;)
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Schnell
« Reply #3 on: October 03, 2013, 02:53:46 PM »
38/39 mpg here
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline cheftuskey121
  • Super Newbie
« Reply #4 on: October 03, 2013, 04:17:54 PM »
I get 36-39 around town and to work and back everyday. long highway trips I get 40-46. thats just E10 gas, nothing else added
Offline nccb
  • 1974 CB750 Four
« Reply #5 on: October 03, 2013, 04:19:55 PM »
I guess you better tune ol' Rhonda the Honda up 8)
Offline onetruepunk87
« Reply #6 on: October 03, 2013, 06:16:56 PM »
I get about 30mpg in basically all stop and go traffic to and from work. I've done 1 trip that was almost solely highway and I got 45mpg then. I just filled up and put a little Seafoam in that I had, I'll let you know if it makes a difference.
Offline tlbranth
« Reply #7 on: October 03, 2013, 08:26:49 PM »
No seafoam: 22MPG.
Seafoam: 26MPG.
Pure imagination would be my guess. But with the mileage you're getting you have serious tuning or mechanical problems anyway. I routinely get 40-49 mpg on my 1970 CB750.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline MiGhost
  • What was that about being an
« Reply #8 on: October 03, 2013, 09:06:04 PM »
No seafoam: 22MPG.
Seafoam: 26MPG.
Any increase in fuel mileage when using seafoam would be due to the seafoam cleaning contaminants out of the carb passages, and fuel system. This allows the carbs, and engine to function properly reducing the amount of throttle required. A 1/16th, or 1/32nd change in throttle position will affect fuel mileage.
That said. You have some serious issues with the mileage that you are getting. Try running 1 gear down from your normal riding to keep the rpms up a bit higher. Use 4th instead of 5th etc... The sohc4 really was designed for higher rpm use. This will also help the charging system function better.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
« Reply #9 on: October 03, 2013, 09:20:25 PM »
No seafoam: 22MPG.
Seafoam: 26MPG.
+1, my cb750 gets better mileage than that while dumping gas out of the overflows, averages around 45mpg when not dumping gas, frequent and extended high rpm flogging only seems to make 1-3mpg difference
« Reply #10 on: October 03, 2013, 10:23:11 PM »
No seafoam: 22MPG.
Seafoam: 26MPG.
How much seafoam are you adding?  Enough to alter the calculation?  You are adding more liquid to the volume, yes?
  • I'm back
« Reply #11 on: October 03, 2013, 11:33:26 PM »
+1
I don't rule out products like Seafoam do alter the [I don't know the word, something like viscosity] of gaz somewhat. I had amazing results (much better driveability) with a similar product, but can't recall it improved mileage. Gaz and seafoam are all hydrocarbons. If you add Seafoam there's more of them. ;D
« Last Edit: October 03, 2013, 11:36:25 PM by Deltarider »
Offline Bailgang
  • Scott
  • Indiana
« Reply #12 on: October 04, 2013, 06:28:26 AM »
I would tend to agree with that. I use seafoam from time to time but only as a preventive maintenance routine but never seen any affect on fuel mileage when using it in fact I have to be very careful how much I put in because too much will make the bike run like crap. When I first got my F2 earlier this spring the bike had sat for a while so the PO put about a gallon of fresh gas in it but threw in enough seafoam for 10 gallons of gas with it, the bike ran horrible until I drained the tank and put fresh gas with no extra additives in it.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline lrutt
« Reply #13 on: October 04, 2013, 06:49:31 AM »
I get solidly mid 40's numbers on both my 750's. You're problem is not which gear your in, it's something else. A solid tuneup is due obviously. Also, stock or modded. If stock, do you know if all the jets etc. are still stock. Or has some PO hogged them out with a drill bit or some such. Jet needle stock. Float valves working properly? Choke off? Air cleaner clean? Brakes dragging?
the questions is not the seafoam, it's the MPG.
Offline evanphi
  • Apparently I'm an
« Reply #14 on: October 04, 2013, 07:48:43 AM »
PO put a MAC 4-1 onto it, and I have no idea what their jetting turned out to be. I am pulling the carbs soon and putting stock jetting back in. They probably fudded something up!
--Evan
« Reply #15 on: October 04, 2013, 08:42:17 AM »
Stock jetting may not be appropriate for your MAC.
you'll need to know what is stock for your '75K and what is in there now, if your MAC is open or baffled, intake specifics(airbox w/ new or used filter) or Pods (type-oiled/dry), needle clip position, mixture screw position.
Verify floats are in the correct position
Do a proper bench sync, and prepare for a vacuum sync (once your valve lash, timing and advance, and cam chain are all dialed in)
« Reply #16 on: October 04, 2013, 09:39:33 AM »
Float level will make a huge difference in mpg if it's too high.
Offline evanphi
  • Apparently I'm an
« Reply #17 on: October 04, 2013, 05:01:28 PM »
stock airbox, muffler is baffled (getting the cone eng quiet core soon!), new filter, 3/4 turns on the mix. need to verify float height for sure.
--Evan
Offline tlbranth
« Reply #18 on: October 04, 2013, 05:40:31 PM »
When I first resurrected my 750 after 25 years of inactivity, it was burbling, sooting up the plugs and getting 27mpg. On advice from members here, I chucked the new air filter I got from PartsNmore because I was convinced it was an Emgo and others figured it was stifling air input. Changing to K&N made the biggest change in mileage and smoothness. Fixing leaky floats and dimpled float tangs improved it more. I'm still running rich and working on it but I'm getting well over 40mpg. So anyway, if your new filter is after-market, it's probably an Emgo and you'd be well ahead to write it off and get a good one.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
