Author Topic: Sidecar  (Read 193808 times)
0 Members and 20 Guests are viewing this topic.
« on: October 21, 2013, 04:48:42 PM »
Starting the build with a wheel.
I painted the spare front wheel where it was rusty and got some 6004 bearings (20x42x12) to accomodate the  20 mm rear axle.
Needs a new spacer but it will work.
I will probably cut the axle short, reusing CB750 axle will give me the same axle nut and since I have a spare axle, it´s the cheapest way.
« Last Edit: October 22, 2013, 03:15:09 AM by 70CB750 »
Offline rb550four
Re: Sidecar
« Reply #1 on: October 23, 2013, 03:18:48 PM »
Will you be running a disc brake?
Re: Sidecar
« Reply #2 on: October 23, 2013, 03:45:25 PM »
Technically I could, but no.
Offline MoMo
  • Ride like you're invisible
Re: Sidecar
« Reply #3 on: October 23, 2013, 06:23:51 PM »
So you're building a side car for Dorothy?  Saddlebags too?  and a trunk to boot? seems  8)...Larry
Re: Sidecar
« Reply #4 on: October 23, 2013, 06:30:04 PM »
That's the idea  ;D
« Reply #5 on: October 25, 2013, 06:13:59 AM »
Got me a shiny NOS bearing retainer.
« Last Edit: October 25, 2013, 01:39:42 PM by 70CB750 »
Re: Sidecar
« Reply #6 on: October 25, 2013, 01:40:05 PM »
...and made crude wrench to install it.
Re: Sidecar
« Reply #7 on: October 30, 2013, 05:18:11 PM »
I will use the better of the two shocks. They came off of 1982 CB900 Honda. Looks like the shock needs 9-10 ounces of oil. The are pretty stiff, but from what I understand, sidecar needs that.
« Last Edit: October 31, 2013, 05:19:07 AM by 70CB750 »
Re: Sidecar
« Reply #8 on: November 06, 2013, 05:26:05 PM »
The wheel swing arm will hinge on 20mm shaft in bronze bushings.  Turning the bushing housing.
The housing is generic length now, will have to cut it to precise dimensions when the time comes.
« Last Edit: November 06, 2013, 05:29:50 PM by 70CB750 »
Re: Sidecar
« Reply #9 on: November 09, 2013, 05:48:01 AM »
I think it needs brake.
Offline rb550four
Re: Sidecar
« Reply #10 on: November 11, 2013, 05:27:13 PM »
Are you planning to use an auxiliary master cylinder that is operated by the ( foot) brake pedal?  Or are you already running a disc for the back wheel on your bike now?
Re: Sidecar
« Reply #11 on: November 11, 2013, 05:55:30 PM »
I can go either way since it will eventually be attached to a bike with 78 F wheels but i like the double pedal and sidecar brake cylinder better.
Re: Sidecar
« Reply #12 on: November 13, 2013, 02:08:24 PM »
This should hold the axle, just gotta drill it 20mm with decent precision
Centering on hole without dogs.
Re: Sidecar
« Reply #13 on: November 13, 2013, 02:51:39 PM »
 Are you going to build a leading link for. The front ?
Re: Sidecar
« Reply #14 on: November 13, 2013, 05:45:49 PM »
It depends how serious I will get with sidecar riding, I am certainly not planning one now.
Re: Sidecar
« Reply #15 on: November 13, 2013, 06:09:54 PM »
The axle will get shortened eventually.
Re: Sidecar
« Reply #16 on: November 14, 2013, 01:19:10 PM »
Another mockup, the caliper will work better between the axle and swingarm pivot and there will be more space for the shock.
Offline kghost
Re: Sidecar
« Reply #17 on: November 14, 2013, 01:49:37 PM »
Cool stuff!
I read all the sidecar threads and want one for one of my 750's
Stranger in a strange land
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
Re: Sidecar
« Reply #18 on: November 14, 2013, 02:09:57 PM »
Oh, so in! Love sidecars :)
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline MoMo
Re: Sidecar
« Reply #19 on: November 14, 2013, 02:19:03 PM »
Prokop,  I think I finally figured out why you want a sidecar....................................................to bring home the deer you kill with Dorothy, right? ::)...Larry
Re: Sidecar
« Reply #20 on: November 14, 2013, 04:25:20 PM »
Thanks guys!
I found nice Velorex to fix but HQ said I need a gun safe first.
Larry, almost spot on, except I would like to have it done before my old airedale goes to better place, he is gonna love to ride the sidecar.
Re: Sidecar
« Reply #21 on: November 18, 2013, 04:22:58 PM »
Bearing spacer for 20mm axle.
Re: Sidecar
« Reply #22 on: December 07, 2013, 08:29:18 AM »
Installed Shinko on the sidecar wheel, great deal on the tire on cyber
Monday
Re: Sidecar
« Reply #23 on: December 07, 2013, 08:29:56 AM »
Tire balanced.
Re: Sidecar
« Reply #24 on: December 07, 2013, 01:06:34 PM »
Next timeyou build inner wheel spacer, you may want go use smaller material, with 2 shopmade washers pushed on.
