Author Topic: winter upgrades for cb500  (Read 2321 times)
Offline Hrvatski Medvjed
« on: October 24, 2013, 07:17:13 PM »
It's getting cold in Minnesota and after riding in snow flurries and 28 degree temps a couple of days ago, I can't help but ponder my winter upgrades and the spring road trip I have planned with a couple of my riding buddies. Now then, I'm not looking to go crazy with mods (no big bores unless I open her up and there's a reason to do a lot of work) but I wouldn't mind getting a little more acceleration and a little more top end out of it.
Here's what I'm thinking:
Electronic Ignition - which one are you using and are you pleased?
650 or Aftermarket "hot street" cam and valve springs- recommendations?
Ported head work (if I can find a good shop near the twin cities to do it) - is it worth it?
CB750 carbs - is it worth it? Anyone have tips for this one?
Trying to gain a little bit while doing most of the work myself and hopefully not having to explain too many expenses to the boss :-)
1973 CB500 - Basically Stock and runs quite well.
Thoughts/Tips are greatly appreciated
"Two Possibilities Exist...Both are Equally Terrifying" - Arthur C. Clarke
Offline Tews19
  • I am no
Re: winter upgrades for cb500
« Reply #1 on: October 24, 2013, 07:20:47 PM »
Get a running 650 engine..... 20 percent jump in HP I think...... only 2 lbs heavier then a stock 550 engine..... I know it is a direct bolt in swap for a 550 so I think may be the same for a 500 frame... If you can find a running engine, say for a few hundred. A 650 wire harness, with carbs... You can have it done in an afternoon....
1970 Honda CB750 survivor.
« Reply #2 on: October 24, 2013, 08:31:07 PM »
Hmmm...hadn't considered that as an option, that might be fun if I can find something reasonable. Still like the idea of pepping up the 500 motor though...
Offline Tews19
  • I am no
« Reply #3 on: October 24, 2013, 08:43:23 PM »
You can get complete running 650's for dirt cheap... Seen some go for as little as 350 bucks around here... In WI
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: October 25, 2013, 08:26:45 AM »
Since you would be swapping into your 500 you don't need to be concerned about a title, which gives you lots of leverage when looking at a running 650.
As far as your current engine goes "runs quite well" translates to "leave the damn thing alone" to me.
If you want to do engine work, get a different engine ans swap it in when it is done. Then you don't run the risk of still having a non-running bike in the Spring when it is trip time. Because you know how pissed you will be if you don't get to ride because you decided to mess with a good running bike and couldn't finish it in time or just can't get the modified engine dialed in.
Offline Mo
« Reply #5 on: October 25, 2013, 11:23:04 AM »
650 engine will drop in, but will require the mounting bracket (only one of them, the rest are the same. Forget which. I believe Scott has done this) from the 550. Also, as mentioned the wiring harness, clutch cables, carbs.
The 650 camshaft in a 500 is not worthwhile without the 650 pistons. (Domed in a 650 vs flat in a 500, giving it the desired compression ratio).
Electronic ignition won't give you power. I have it, and its advantage is I never have to mess with points. PAMCO makes a good unit.
Offline Tews19
  • I am no
« Reply #6 on: October 25, 2013, 06:49:45 PM »
Why wouldn't a cam swap be helpful? It helps with mid range from what I have read... I have a 650 cam waiting on my 550 engine build for this reason... You do not need to swap out pistons or anything to notice a gain.... The cam will be fine.
Offline Tews19
  • I am no
« Reply #7 on: October 25, 2013, 08:32:48 PM »
Not sure how close you are but here is a complete running 650... The yr in the listing is incorrect...
http://mankato.craigslist.org/mcy/4082504579.html
Offline Bailgang
  • Scott
  • Indiana
« Reply #8 on: October 26, 2013, 05:56:48 AM »
I don't know what Mo is referring to but a 650 cam in my 550 really woke the engine up. I later on installed an adjustable cam sprocket so I could advance the valve timing 6 degrees which woke up the mid range even more, I lost a bit of top end power by advancing the timing although I actually never noticed it because it still pulled like a bear when it hit 7k rpm up to redline. I had also installed kibblewhite valve springs.
Installing a good 650 engine would definitely be more cost effective and "easier" but I've never been known to do things the easy way simply because I like the challenge. Back in the day when all my brothers and friends were racing either Fords or Chevy's I instead chose a Pontiac.  ???
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Mo
« Reply #9 on: October 27, 2013, 11:23:20 AM »
I guess I might be wrong here, but I always read that because the pistons were different, you wouldn't get the full benefit. Maybe that was for a 550 and not a 500?
Anyways, I guess I have been corrected.
Offline Bailgang
  • Scott
  • Indiana
« Reply #10 on: October 27, 2013, 12:12:01 PM »
Well I guess the OP was referring to installing it in a 500 not a 550 like I did so you might have a point.
Scott
71 cb350 twin
77 cb750 F2
« Reply #11 on: October 27, 2013, 07:02:35 PM »
I had always read that a 650 cam would swap in direct and increase mid range output...either way, I might go for the cam and valves springs, but, i'm fairly set on carbs and ignition - skip on the porting. This bike runs good so I don't want to ruin it!
Offline Bankerdanny
« Reply #12 on: October 28, 2013, 08:18:22 AM »
The best way to not ruin a good running bike is to not mess with the engine. You can't mess it up if you leave it alone.
« Reply #13 on: October 28, 2013, 08:39:18 AM »
Seems like fairly sound advice. Not always the most fun but, sound nonetheless.
Offline Bankerdanny
« Reply #14 on: October 28, 2013, 11:36:20 AM »
I only point this out because you have mentioned on several occassions how well it runs.
A quick run through the threads here will turn up hundreds of threads about poor running bikes and many are because the owner decided to make just because.
I agree that building up an engine would be fun, but as I suggested before, find yourself a stand alone engine and built it. That way you can enjoy riding the bike while you do.
