Author Topic: Correct Fuel Hoses for 74 CB750?  (Read 8689 times)
Offline Jim Harris
« on: October 28, 2013, 06:53:10 AM »
Good morning!
I'm still cleaning up that 74 CB750 barn find that we talked about last week and I have a quick question about the fuel hoses. The hoses that came with the bike look like replacements. They are black rubber hoses and I'm not sure they are routed and hooked up correctly. I've attached some photos. Photo 27 shows the markings on the large hose, which is all Greek to me, but maybe it will mean something to you guys. The large hose goes from the petcock across the top of the carb set to a fitting just above carb 1 (driver's left) see photo 28. The smaller hose runs from the petcock under carb 4 to a fitting above carb 4 (see photo 31). I guess the inside diameter of the existing hoses must be correct or they wouldn't fit the fittings on the petcock or the carbs, but they look big. Does everything look OK to you guys? Should I just go ahead and order the correct OEM fuel lines (95001-35003-60M) or will any gas rated hose be OK as long as the ID is correct?
Thanks!
1969 Honda CB750 K0 - Candy Ruby Red
1972 Honda CB750 K2 - Candy Gold
1974 Honda CB750 K4 - Freedom Green Metallic
1976 Honda CB750 K6 - Candy Antares Red
(2) 2000 Honda ST-1100
1973 Honda CB450
Re: Correct Fuel Hoses for 74 CB750?
« Reply #1 on: October 28, 2013, 07:01:45 AM »
The hose with the writing on it is not stock of course. Does it fit through the hole in the carb bracket visible in the bottom picture as it should route through that or is it too fat ?. If the bike is a runner now good fitting fresh fuel line is a good thing. You will get some suggestions
fendersrule
« Reply #2 on: October 28, 2013, 07:14:18 AM »
Get the proper hose. It typically has to be ordered. You want 3/16" I believe.
I got tired of running "over the counter" black hoses that were basically the same size that you have in the picture. Even with clamps (which are very hard to use on the carb inlet), the hose would still leak if it wasn't perfectly seated. They also are not flexible and don't work in some situations on certain bikes.
The old hose also required clamps. A 3/16" hose doesn't require any clamps.
This is a moose racing hose with your usual filter. It's nice being able to see the fuel too:
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: October 28, 2013, 07:15:41 AM »
I'm not certain about the 750s, but here's the part # for 5.5mm hose, get it from your local Honda dealer.  ;)
95001-5500160M - 5.5mm - Black
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Toxic
« Reply #4 on: October 28, 2013, 07:21:16 AM »
Yes, 5.5mm is stock but I can't get it in Canada, at least I haven't found a supplier.
There are lots of guys using the 3/16" with no fuel starvation issues and it's available everywhere.
DH
« Reply #5 on: October 28, 2013, 07:29:25 AM »
Here's routing pics, for a stock K4 with 2 fuel outlets, w/valve on right side.
« Last Edit: October 28, 2013, 07:33:15 AM by DH »
Offline Jim Harris
« Reply #6 on: October 28, 2013, 07:42:58 AM »
OK, so let me make sure I'm understanding your photos correctly...
First of all, it looks like both hoses in your photos are the same OD, so that they can fit through the holes in the mounting plate (3/16" ID)?
Second, what I now have as a huge black rubber house laying on top of my carbs really should be threaded under carb 4 then through the mounting plate and then looped to the inlet near carb 1?
Does it make any difference which hose is connected to which outlet on the petcock?
Thanks!
1973 Honda CB450
DH
« Reply #7 on: October 28, 2013, 07:49:15 AM »
Long line from 1/2 carbs thru upper hole. Short line from 3/4 carbs thru lower hole.
Long hose to front most port on valve, short hose to rearmost port on valve.
Cut hoses to length as listed...Sorry, don't know what diameter the hose is. These instructions are from a kit I bought from ebay seller dgs38...BOTH installed hoses should be the of the same diameter.
« Last Edit: October 28, 2013, 08:12:19 AM by DH »
« Reply #8 on: October 28, 2013, 08:01:49 AM »
Yes, 5.5mm is correct for CB750. Usually not available from local haedware. It is 7/32".
3/16" is too tight and will split if its a cheap hose. It will work if its good quality and you can force it on.
1/4" is too loose, but will work if held on with a clamp.
We had a couple of selling programs where a member bought a quantity of 7/32 from this place and then resold smaller amounts to members. No such programs lately though.
http://www.alssnowmobile.com/PRODUCTPARTS.ASPX?pn_deptid=304
The price is reasonable but they have a $12 S&H. So you got to buy a bunch to make it worthwhile, then sell off to cover your costs.
Offline Jim Harris
« Reply #9 on: October 28, 2013, 08:07:46 AM »
Got it, I'll order the right size hoses and route them the correct way.
Thanks!
1973 Honda CB450
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #10 on: October 28, 2013, 10:02:21 AM »
7/32nd is what I use and can buy it locally in a kit at Nebraska Motorcycle parts in Omaha.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Jay Ace
« Reply #11 on: October 28, 2013, 10:02:38 AM »
A bit pricey but the hose is perfect size and slips on and off super easy and no need for claps and it doesn't leak either!
http://www.ebay.com/itm/400529470310
Offline goldarrow
  • one day, i'll be an
« Reply #12 on: October 28, 2013, 02:38:00 PM »
may be i should look into doing this again once more
CB550 K0
Offline Frostyboy
  • Circa 1951
« Reply #13 on: October 28, 2013, 04:41:33 PM »
David Silver has an American store now, they have genuine hose in stock.
http://davidsilverspares.com/parts/by-part-number/partnumber_26345/
We haven't met yet.
[CB550F1]
Offline bjbuchanan
« Reply #14 on: October 28, 2013, 04:53:11 PM »
They fist you on shipping though
« Reply #15 on: October 28, 2013, 06:19:52 PM »
I've got all I need, but if you chat it up, you'll probably sell out. Other than those that just have to have black, the semiclear colors are the way to go.
« Reply #16 on: October 28, 2013, 06:58:42 PM »
you can get tygon at any mower shop. Bends nice an no clamps
Offline tomkimberly
« Reply #17 on: October 28, 2013, 07:04:12 PM »
Don't all Japanese motorcycles use the same size fuel hose?
If my local Honda dealer is out of hose, I just go to a Yamaha, Kawasaki, or Suzuki dealer.
Tom
« Reply #18 on: October 28, 2013, 07:10:27 PM »
I get 5.5 at my local Yamaha dealer...
« Reply #19 on: October 28, 2013, 09:03:02 PM »
Yep - I was right you got a few suggestions   ;D
