Author Topic: Can someone verify this seal, and damping rod question  (Read 2446 times)
Offline heyitsrama
« on: November 03, 2013, 06:04:27 PM »
Howdy,
making progress on one of the forks today.
I got a little mallet happy when i was placing the new fork seal into the lower.
I only realized the position when i compared it to the other one.
Should i pull it out, and order new new seals? or just let it be?
Part 2.
in this rebuild guide
http://www.motorcycleclassics.com/mc-how-to/honda-cb500-fork-rebuild.aspx#axzz2jddSFKow
In the second object to the top there is this long damping rod that goes inside the tube. I did not find them on my 72' CB500? Should i attempt to source them, anyone else find this?
Thanks! :D
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Re: Can someone verify this seal, and damping rod question
« Reply #1 on: November 03, 2013, 10:12:32 PM »
if it went in easy and you didnt use sealant around it you might carefully and evenly pry/lever it out again and reuse it?if you damage it your up for a new seal anyway,id give it a go.
« Reply #2 on: November 03, 2013, 10:43:32 PM »
Only the early 500's have the long rod, the later ones the damper assembly will not slide out of the bottom as there is a collar welded into the steel fork tube
Offline heyitsrama
« Reply #3 on: November 04, 2013, 12:14:50 AM »
funny you say that, mine is completely disassebleable, but with no rod.
ill have to look out for the dwarfs.  :o
72' cb500
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: November 04, 2013, 01:40:57 AM »
Usually you have to tap the seal down until it bottoms on the shoulder in the slider, as you have done, and in it's seated position the top of the seal is just below the clip groove. I have not seen one before where there is such a gap between the seal and the clip, which leads me to wonder if you have the correct seal?
It's been a long time since I've had my 750 forks apart, perhaps someone can verify?
« Last Edit: November 04, 2013, 05:04:05 AM by oldskoolnuts »
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline lucky
« Reply #5 on: November 04, 2013, 09:43:32 AM »
Don't worry about it.
It will not be a problem.
The seal does not bottom out on anything.
« Reply #6 on: November 04, 2013, 11:41:51 AM »
if it dosent bottom out lucky itll do a status quo and go down down deeper and down,down down deeper and down?
Offline heyitsrama
« Reply #7 on: November 04, 2013, 12:22:05 PM »
Its a K&S fork seal NO 16-1020
 • 35mm x 48mm x 11mm
I think the placement on the one i just did was off, and too far deep I don't think ill be able to pull it out without damaging it....
72' cb500
Offline martin99
  • UK Based, Non-
« Reply #8 on: November 04, 2013, 03:37:47 PM »
Well that's the correct seal according to my parts list, so I guess that's how they fit. Sorry if I confused the issue. Personally I'd still have it sitting on that shoulder though, at least you know it's in square that way.
Build threads:
1977 CB750 F2
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #9 on: November 04, 2013, 04:04:28 PM »
Thanks! :D
That's the damper - part #51430-323-020. That part and everything else on that towel belongs in all CB500K '71-'73.  But it sounds like someone swapped CB550 forks into your bike. If so, just leave it be. The dampers won't work with the CB550 forks.
« Last Edit: November 04, 2013, 04:09:56 PM by chickenman_26 »
MCN DTF
Offline lucky
« Reply #10 on: November 04, 2013, 04:08:12 PM »
I have put them in both ways and it seems to make no difference.
They can be all the way down on the shoulder or flush with the top.
I have never felt any difference.
Offline heyitsrama
« Reply #11 on: November 04, 2013, 06:06:20 PM »
thanks lucky!
Now i just need to figure out what i want to do with the headlamp ears, then get these forks back on.
AHH i find more and more surprises from this bike, is there any other badging that i can look, and confirm that its a 550 set?
72' cb500
« Reply #12 on: November 08, 2013, 02:17:17 PM »
I just realized that the picture came off a website and isn't your parts. Have a look at the 550 pic below. If your fork tubes look like this (groove around bottom of chrome tube) and the top nut isn't threaded underneath to attach the damper rod, you have 550 forks.
MCN DTF
