Author Topic: Carbs don't snap back even without cables connected  (Read 605 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: November 27, 2013, 05:45:34 AM »
Manually operating the butterfly with no cables attached. Open to full throttle, let go, carbs snap to 2/3 closed, and slowly drop the last 1/3 of slide travel. Again... no cables attached.
Are there bushings on the lifters that need oiling? Lube the slides? New spring? I just pulled the carbs and cleaned the jets, but didn't have the slides out or anything.
Was snapping closed just fine before I had the carbs off,as far as I can remember.
1975 CB750K.
--Evan
1975 CB750K "Rhonda"
Offline Johnie
Re: Carbs don't snap back even without cables connected
« Reply #1 on: November 27, 2013, 06:29:32 AM »
Try loosening the the carb slide tops to reseat the slides. They maybe are hanging up in there. If you never had the slides out then they may need a cleaning.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline evanphi
  • Apparently I'm an
« Reply #2 on: November 27, 2013, 06:35:46 AM »
They were snapping back fine when I had them off the bike.
By slide tops you mean the screw on caps that go on each carb body?
--Evan
« Reply #3 on: November 27, 2013, 07:31:32 AM »
A few ideas...
Return Spring is not doing it's job. Too weak, not original, or not connected.
Slides are varnished.
Bent needle or varnished needle jets.
Offline Johnie
« Reply #4 on: November 27, 2013, 08:28:00 AM »
Yes, the screw caps. It was just an idea as I had the slides out and tightened those caps down to soon. They were a little out of line with the slide shaft.
Oshkosh, WI  USA
Offline Sprocket75
« Reply #5 on: November 27, 2013, 08:43:59 AM »
Loosen the screws on the plate that all of the carb bodies are attached to. Then loosen the linkage a little between them. Start snugging them back down little by little checking the slide action as you go. Tighten where necessary. Sounds like you've got them torqued/torsioned somehow. I had the same exact issue when I took mine off. This solved it for me.
..."Always two there are, no more, no less. A master and an apprentice"... YODA
1975 Honda CB550K
Offline evanphi
  • Apparently I'm an
« Reply #6 on: November 27, 2013, 08:45:54 AM »
Thanks for the suggestions so far. Won't be back out to the bike for a few days, but I will pull them off again and check them over.
--Evan
Offline jtb
  • An unlikely
« Reply #7 on: November 27, 2013, 05:56:23 PM »
+1
1977 CB750F
1985 V65 Sabre
