Author Topic: CB 750 four ignition switch  (Read 892 times)
Offline Sgt.Pinback
« on: November 30, 2013, 07:04:26 AM »
Found the original ignition switch for my 1970 K0  :)
But there two problems:
- it worked good for some times, I put some grqhite into it and no now it will not turn / is blogged
- does not keep the key. Key falls of.
How may I fix this?
Is there somewhere a specialist who may repair it?
Doc, I love a motorcycle!
Offline Johnie
Re: CB 750 four ignition switch
« Reply #1 on: November 30, 2013, 02:13:03 PM »
Had that happen with my KO switch. Pull the rubber down and you will see a hole. I put some spray lube in there...not much. Just enough to slick up the contacts. Been working for 6 years now.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Sgt.Pinback
« Reply #2 on: December 01, 2013, 07:29:24 AM »
Something like WD-40? Whont that stick down after some time?
Offline Johnie
« Reply #3 on: December 01, 2013, 10:55:28 AM »
I had first used contact spray which cleaned the contacts so good I could not move the key. I put in some electrical contact lube. You will have to check to see what is available in your area. WD40 is a solvent which will displace water, not really a lubricant.
Oshkosh, WI  USA
Offline RSchaefer
« Reply #4 on: December 01, 2013, 05:50:24 PM »
This is what I have used with great success http://www.whitelightningco.com/.  I live in the desert and we need a lubricant that does not attract dust, in fact ejects the dust as a part of the lubrication function.  This is the stuff I use.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
