Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Engine breather hose goes there.
Quote from: brewsky on December 06, 2013, 03:46:36 AMEngine breather hose goes there.Actually, that's where a drain hose attaches. Engine breather hose routes to a small elbow connected to the base of the air filter box. Here's more info:http://forums.sohc4.net/index.php?topic=86697.msg1216567#msg1216567
SohRon - looked at forum doesn't show hose hooked to it in diagram. Do i just need to get a hose and run it down behind the engine with the rest. Mine had about a 2 in long hose that was cut. Oh and I wish my engine was even close to as clean as that.doing some research if 500 is the the same axle if any knows please chime in
